C63 AMG (W204) 2008 - 2015
"Check Coolant Level" - Take to dealer or DIY?
Old Apr 29, 2016 | 01:45 AM
CarHopper's Avatar
E63S | X5
Originally Posted by VanC63
Thats the worst reply I was looking forward to reading lol. Is there any recalls on this head bolt issue?
It's a known issue, but the one thing that MB hasn't stepped up for. Sorry I didn't sugar coat it.
Again though, your initial post was somewhat vauge. Head into the FAQ, dive into the headbokt threads, and then come back.
Scan your car for CELs too.
We're here to help.
Old Apr 29, 2016 | 03:17 PM
Mr. Lin's Avatar
2008 C63
15 minutes and all the coolant was gone? that had to be a rather large gap, but if your engine shut down because of it, that makes sense. you didn't notice any white smoke?
Old Jun 8, 2020 | 12:34 PM
Gary Maranjyan's Avatar
2012 MERCEDES BENZ C63 AMG EDITION 1
JUST GOT IT
Whats up boys? Quick question, I'm too worried because I got the check coolant level on my 2012 c63 eiditon 1, but my engine number tells me I am not in the affected group for bad head bolts, should I still worry? Kinda ruined my whole day and I think im iverthinking.
Old Jun 8, 2020 | 01:33 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You have a FL car so no headbolt issue. Coolant contracts/expands with changes in season. Just top off the overfill tank with some distilled water or Redline Diesel WaterWetter.
Old Jun 8, 2020 | 01:44 PM
Thank you brother, made my day!
Old Jun 8, 2020 | 03:28 PM
ecohen2's Avatar
Originally Posted by tfthach13
Take it in. I'm at my dealership right now for the same problem. They just told me it was the coolant cap that wasn't holding pressure. They simply replaced it. They checked for the headbolt as well and that wasn't the issue.
I would check the cap as well especially you see any white near or on the tank... We have 4 Mercedes including my C63 and all of them have the exact same issue with the cap.. You can try the following:
1. With the engine cold, remove the cap.
2. Take a damp rag and clean the o-ring that is on the cap. I am not 100% sure why but the o-ring gets crusty residue on it then does not hold pressure.
3. Clean out the entire inside lip where the cap and o-ring go into the tank.
4. Top off the coolant with the correct color/type. If you mix red and green you will destroy your engine and I have no idea if Mercedes kept them the same.
You should not see the problem again unless that o-ring is torn..
Ed
Old Jun 8, 2020 | 03:34 PM
  #32
Thanks, will do. Ill get back to you guys.
