C63 Service
C63 Service
Hi guys,
Getting my C63 serviced (B Service).
Mercedes no longer use Mobil 1 so I wanted to know will it be ok to shift to the new oil they use? My C63 has always used Mobil 1 0w-40 so will the change be ok?
I'm also getting this stuff done at Mercedes:
Engine Oil and Filter Change (FUCHS oil 0w-40)
Change Brake Fluid
Mercedes Cabin Filter
Mercedes Coolant and Cooling System Cleaner (flush)
Transmission Service and Reprogramming if needed
Spark Plugs
Full inspection
I was going to get the diff oil changed but the service guy said not to waste my money. The diff seal was leaking and was repaired so new oil was put in a few months ago, so was told not to bother changing it.
Have i missed anything? Does anyone recommend anything else? Do's and Dont's?
Change Brake Fluid
Spark Plugs
Full inspection
Hi guys,
Change Brake Fluid
Spark Plugs
Full inspection
Thanks![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Change Brake Fluid
Spark Plugs
Full inspection
Looks like an exhaustive list.
Most of it can be DIYed which can save you even more $$.
I would let them do the coolant/cooling flush and transmission service.
abcut973 - thanks for the info, i'm only taking it to mercedes because i'm being looked after and i don't have time to run around and do it all.. i'm working flat out because it's the end of year
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
My dealer has no problem with me providing my own Mobil 1 oil at service time. I pick it up from one of the discount car parts places. From memory it works out a bit cheaper than the prices MB would charge you for their stuff as well.
Mobil 1 remains on the approved list of oils for the M156 motor but MB "dropped" them as their preferred oil company on the back of a falling out over sponsorship in F1 racing.
A list of MB approved oils and lubricants available here:
http://bevo.daimler.com
then enter the relevant MB Sheet number for the C63 ie 229.5
re your proposed service schedule my dealer is telling me the coolant is good for 250000km or 15 years, so maybe you could leave this off the list for a while, particularly if you are due big ticket items like transmission flush and change of spark plugs
The tribiologist that is doing my UOA reviews (Terry Dyson) will tell you to try the FUCHS. He is not a fan of Mobil 1. He would also say to back it up with a UOA just to confirm.
Hi guys,
Change Brake Fluid
Spark Plugs
Full inspection
Change Brake Fluid
Spark Plugs
Full inspection
my wife bananas! :D
haha yes... as long as its on the approved list... use whatever. Your car doesnt suddenly develop an allergy to mobil 1 once the sponsorship went south.
funny enough. i had a discussion with a member here who swore by mobil 1.... saying that if MB put the mobil 1 sticker on the car,... it must be the only thing that it can take. i had to laugh.. and laugh hard. I'm using motul myself... so much better. especially since mobil 1 in NA.. I heard, is actually different than the european version
my wife bananas! :D
Awesome. Obviously FUCHS would be on the approved list if Mercedes/AMG is using it yes?
I hope it responds well to a highly modified/tuned C63 though.
