C63 AMG (W204) 2008 - 2015
Weistec Oil/Air Separator Return Into Sump?
Old Nov 25, 2013 | 01:43 AM
charliekay's Avatar
C63 AMG
So I got my Weistec Oil/Air Separator today and am going to have it fitted next week.
I was thinking about running the oil back into the sump but not sure if it is a good idea or if it has been done before or if it can be done, maybe someone here has tried or thought about it previously.
Thoughts?
Charlie
Old Nov 25, 2013 | 02:22 AM
Merc63's Avatar
C63 AMG
Doesn't work that way. Toss it out. Are u trying to save 5 cents?
Old Nov 25, 2013 | 02:43 AM
charliekay's Avatar
C63 AMG
Lol. Its not about saving the oil. Its more the worry about having to empty the catch can and/or it overflowing.
Im not a mechanic hence the question. It was an idea and I thought it would be best to ask the more experienced.
Old Nov 25, 2013 | 03:53 AM
YICS NZ's Avatar
C63s AMG W205
It can be done with a different design which involves returning tubes n circulating coolant in the separator itself to keep the oil from become frozen when the car is used in extremely cold seasons. My 11 STI has got one like that, which is basically maintenance free (but takes longer to install).
Considering how little the oil is collected by the separator its probably not worth the extra hassle.
Old Nov 25, 2013 | 04:47 AM
Merc63's Avatar
C63 AMG
Unscrew it every month and you should be fine.
Lefty loosie
Old Nov 25, 2013 | 09:16 PM
roadtalontsi's Avatar
10 C six trizzle
the point of it is to prevent oil from going into the intake system since it is applying vacuum to the crankcase since it makes so much pressure. If you returned it to the crankcase it would defeat the purpose.
Old Nov 25, 2013 | 10:00 PM
charliekay's Avatar
C63 AMG
Lefty loosie
Thanks for the input guys, this is the sort of info I was looking for.
I'll install it the way Weistec designed it and empty it regularly.
Old Nov 25, 2013 | 11:05 PM
CPD SLK's Avatar
2009 C63 AMG
Just curious....how much is your shop charging for the install?
Thanks!
Old Nov 26, 2013 | 01:06 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Thanks!
That is a simple DIY. Don't waste your money on install.
Old Nov 26, 2013 | 10:45 PM
10 C six trizzle
while i can agree with you on one hand, on the other people dont have the tools or knowledge to change a light bulb or even air filters which in that case they need to leave it to the pros.
