C63 AMG (W204) 2008 - 2015
Head Bolt Affected VIN - 2010 & older, & early 2011s
Old 12-07-2014, 04:56 AM
  #251
adrian.sole's Avatar
AMG C63 2011
Can you please check this VIN and can I have the data card please
Hi Joe,
This is my 2011 C63 VIN - wdd2040772a605062 - would be nice to have a data sheet as well.
Can you check to see if this motor is effected by the Head Bolt issue - also if it is not does it also mean the issue with the premature camshaft wear is also resolved?
Anything else the updated motor resolves?
Regards
Adrian Sole
Old 12-07-2014, 11:25 AM
  #252
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by adrian.sole
Hi Joe,
Regards
Adrian Sole
Datacard attached.
Regards,
Joe
File Type: pdf
Old 12-07-2014, 02:05 PM
  #253
swagkingcole's Avatar
09 C300 4MATIC, 09 C63 AMG
Originally Posted by Valvestud
Datacard attached.
Regards,
Joe
can you check this one as well?
WDDGF77X68F152839
thanks!
Old 12-07-2014, 02:57 PM
  #254
Valvestud's Avatar
WDDGF77X68F152839
thanks!
Again, all 2010 and older, and some early 2011s are affected.
Regards,
Joe
Old 12-08-2014, 01:25 AM
  #255
AMG C63 2011
Thank you Joe for the data sheet, can you confirm if motor is not effected by the head out issue?
Old 12-08-2014, 05:43 AM
  #256
horific's Avatar
2011 C63 AMG P31
Joe,
Just bought a 2011 Vin: WDDGF7HB5BF582744 can you tell me if it's affected and share the data sheet.
Also i don't know if people have told you enough but you're helping a lot of people on here and it's really great of you to step up.
Thanks from all of us.
Chris
Old 12-08-2014, 08:23 AM
  #257
Valvestud's Avatar
Just look at last 5 digits of engine serial number. If greater than 60658 you're in good shape.
Regards,
Joe
Old 12-08-2014, 11:51 AM
  #258
Valvestud's Avatar
Originally Posted by horific
Joe,
Chris
Car is not affected. Datacard attached.
Regards,
Joe
File Type: pdf
Old 12-08-2014, 01:52 PM
  #259
2000UZJ's Avatar
E55
Joe,
Thanks for doing all this! Can you tell me if this VIN is in the range of affected motors?
2010 E63 - WDDHF7HB0AA108944
Thanks!!!
Nick
Old 12-08-2014, 01:58 PM
  #260
Valvestud's Avatar
Originally Posted by 2000UZJ
Joe,
Thanks!!!
Nick
Regards,
Joe
Old 12-08-2014, 02:06 PM
  #261
2000UZJ's Avatar
E55
Regards,
Joe
I read as much as I could. Guess I missed it. I'll pass on this one. Thanks for the heads up.
Old 12-09-2014, 01:27 PM
  #262
Chris05STi's Avatar
2010 E63
Can you please check my vin WDDHF7HB3AA092089
Thank you
Old 12-09-2014, 02:10 PM
  #263
Valvestud's Avatar
Thank you
See post #260 above.
Regards,
Joe
Old 12-16-2014, 01:59 AM
  #264
mltoe63's Avatar
ML320(gone),E63 AMG
Could you please check this VIN:WDDHF7HB9AA107159 and may I request a datacard as well. Many Thanks.
Old 12-16-2014, 08:47 AM
  #265
Valvestud's Avatar
Datacard attached.
Regards,
Joe
File Type: pdf
Old 12-17-2014, 12:33 AM
  #266
sbtm's Avatar
2012 E63
Hi Joe,
I've got a 2011 (2012 model) E63. Can you please check if my car is affected and get me the data sheet?
VIN: WDDHF7EB5CA550545
Many thanks.
--Sadiq
Old 12-17-2014, 08:14 AM
  #267
caldwellm's Avatar
'16 AMG GTS, '14 Continental GT, '15 RR Supercharged
Do you mean that you have a 2012 E63 that was built in 2011?
Old 12-17-2014, 08:50 AM
  #268
Valvestud's Avatar
Originally Posted by sbtm
Hi Joe,
Many thanks.
--Sadiq
Your car is a 2012. It has an M157 engine not M156.
Datacard attached.
Regards,
Joe
File Type: pdf
Old 12-18-2014, 12:09 AM
  #269
sbtm's Avatar
2012 E63
Datacard attached.
Regards,
Joe
Many thanks Joe. You're the best!
--Sadiq
Old 12-20-2014, 08:07 AM
  #270
Stiggs's Avatar
2003 CLK55
I've been shopping around for a used ML63 recently.
One I found had a carfax that stated the "Intake manifold gasket(s) replaced".
Does this mean the head bolts were replaced as well? Just curious if this means this engine is safe from head bolt failure now. Thanks.
Old 12-20-2014, 11:27 AM
  #271
Valvestud's Avatar
That repair has nothing to do with headbolt replacement.
Regards,
Joe
Old 01-02-2015, 08:55 PM
  #272
Amgforlife5's Avatar
2010 e63
Head bolt
Can you please do mine WDDHF7HB2AA173696
Old 01-02-2015, 09:27 PM
  #273
Valvestud's Avatar
All 2010 and older and some early 2011s are affected.
Regards,
Joe
Old 01-03-2015, 11:19 AM
  #274
e63amg4life's Avatar
x5 3.5d
Is this repair expensive at the dealership
Old 01-05-2015, 07:05 PM
  #275
2000UZJ's Avatar
E55
Replace them before it becomes an issue. It'll keep your "repair" cost down. If your under warranty it has to fail before it's warrantied.
Quick Reply: Head Bolt Affected VIN - 2010 & older, & early 2011s
