Head Bolt Affected VIN - 2010 & older, & early 2011s
#676
Can you check this 2011 SL63 for me. I am thinking of buying it. I had a 2009 SL63 and had the headbolts replaced on it. I would rather not go through that again.
WDBSK7AA8BF162976
WDBSK7AA8BF162976
Regards,
Joe
#677
#680
11 E63
was hoping you could run my VIN#, too Mr. Joe!
VIN: WDDHF7HB9BA341674 2011 E63 (vin card says car manufacture date was 10/10). many thanks sir!
#682
#684
Regards,
Joe
#685
Hello Valvestud! Thank you for your service going on 3 years now.
Could you please run VIN # WDDHF7HB2BA304000 for me?
#686
wdbarr (11-04-2016)
#687
I am thinking of buying a 2010 (august build) E63, can you check this vin and advise if I need to change the head bolts
WDD2120772A3535579 (oops have a typo in here too many numbers) will need to check the car again
Cheers!
Cheers!
#688
VIN resend not required, as the title of the thread you posted in gives you your answer.
PauloAllen (11-07-2016)
#690
There is new post from Adangg who is seeking to buy a 2008 but is concerned about the head bolt issue. I understood that this was an issue from the onset of the C63W204 until 2011 but a few reads here suggest it was later and not so wide spread. Maybe you could reach out to him and share your knowledge of the subject. His post is Potential 2008 C63 Buyer posted 11/10/2016.
#692
They swapped over to a new design at X engine number. That was early 2011 NA production. The only confusion here is that some other countries (mainly Europe) don't follow the same model year guidelines as NA. https://en.wikipedia.org/wiki/Model_year
It's that cut and dry. The 2008 you mention is 100% affected, unless they were changed post production.
EDIT: To add a little more context. If you have a 2010 and older in NA, you for sure have the older bolt design where as a 2011 there's a slight chance. In Europe a 2011 is a crap shoot. Could be a "late" 2011 that's still affected so you need to check the VIN to be sure.
#693
#694
There was a very high mileage reported failure not that long ago. Not to be a Debbie downer, but you still have the old design that could potentially fail at some point.
#697
2011 c63
#699
Hey Joe, I'm looking at 2011 c63 amg Vin is
WDDGF7HB0BF559730. Any info would be appreciated.
Regards,
Joe
#700
2014 ML63 AMG
2011 E63 check
