Head Bolt Affected VIN - 2010 & older, & early 2011s
Could vin WDD2122772A349669 be checked please? It's a UK 2010.
https://www.vindecoderz.com/EN/check...2122772A349669
Delivery date: 14 10 2010
Engine no.:
156985 60 064480
Here's a 2010 UK C63: WDD2040772F615823
Engine no.:
156985 60 064480
Regards,
Joe
From the website I pulled the following:
Engine #:156985 60 036381
Delivery date: 25 07 2008
Thank you!
Thank you!
From my understanding it would obviously be in the range with the faulty headbolts.
Thank you!
I haven't seen a definitive answer yet, is it better to go with aftermarket replacement bolts or MB's replacement bolts used in newer built motors?
Maybe not as easy to find but, revised OEM bolts are fine unless you're planning on adding a blower in the future, then go ARP (Weistec) studs.
WDDGF77XX9F278767
Thank You!
WDDGF77XX9F278767
Thank You!
looking to buy this car vin WDD2040772F429897
i know the engine is the effected range however tried the vin decoder and it didn't recognise the vin? Now I'm suspicious
any info would be appreciated
its a limited run (63 cars only) for the Australian market. Should have LSD also.special colour and sand colour leather
thanks
brad
thanks
brad
Here you go:
VIN WDD2040772F429897
Delivery date 11 11 2009
PAINT1 046U DESIGNO-PLATINUM BLACK PAINTWORK
Engine 156985 60 053223
Gearbox 722907 02 454626
471 MECHANICAL LOCKING DIFFERENTIAL
P97 SPECIAL MODEL "AMG EDITION"
X10 DESIGNO SAND SINGLE-COLOR LEATHER
So yes, its the Edition 63.
Is that the one with the red wrap at Xotica?
Nice car.
I just picked up a face lift with P31, intake, LTH into twin 3" pipes and tune and I'm from Perth.
Cheers.
