Head Bolt Affected VIN - 2010 & older, & early 2011s
#1076
Cost
If anyone's curious, these are what my original headbolts looked like when replaced in my 2009 C63 with 114,000km on it. Two on the right have been degreased. They were in decent condition and I had plenty of time to have them replaced, but I'm glad it's done with now and I don't need to worry about it. You can definitely see the corrosion starting, though
#1077
I paid $2000 CAD for the parts and labour in the Toronto area. I also had the spark plugs and oil changed at the same time which added a bit to the cost, if I remember correctly the spark plugs were about 200 CAD themselves. Very glad to have it done and out of the way, though. The head bolt work is not something I'd be comfortable trying to do myself
#1079
CyanideRide (07-16-2018)
#1082
2011 ML63
Hi Valvestud, could you please check if my 2011 is affected? VIN 4JGBB7HB9BA665053
Thanks in advance
Thanks in advance
11ML63 (07-03-2018)
#1085
#1087
I guess I didn't understand that ALL cars older than 2010 are affected. I've been unable to locate a definitive answer online. I asked my dealership about the issue and they are being suspiciously tight-lipped. I was under the impression that some cars produced before 2010 have the issue.
Thanks.
Thanks.
#1089
Thanks.
Thanks.
Regards,
Joe
#1091
Strange I purchased my car as a 2010 but the last 2 times I’ve picked up parts at Mercedes they have it listed as a 2011 based on my vin ... about to do the head bolts but I guess I should check to make sure I need them
vin # WDDGF7HB2BF639997
#1092
#1094
Hello, I'’m new to the forum and was wondering if someone could look up my VIN to see if my 2011 C63 is affected and also post the data card so I can confirm my options. VIN: WDDGF7HB4BF585053
Thank you.
Thank you.
#1097
01 C320, 08 M6, 98 ITR
#1099
Regards,
Joe
#1100
Can you please check WDDGF7HB3BF646313 and send the data sheet?
