C63 AMG (W204) 2008 - 2015
Head Bolt Affected VIN - 2010 & older, & early 2011s
Old 08-15-2014, 07:35 PM
  #151
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by Point2Point
Can you check WDDGF7HB5BF528098? This is a 2011.
Thanks!
Sorry, your serial number is 156985 60 060478. You missed switchover by 179 engines.
Is this a US car?
Regards,
Joe
Old 08-15-2014, 08:26 PM
  #152
Point2Point's Avatar
997.2 GT3
Yes, this is a US car.
Old 08-17-2014, 04:49 PM
  #153
skytow's Avatar
2013 C63, 2015 C63 507, 2020 C63s
Hello Valvestud!!
Please look up VIN WDDGF7HB6BF624614
US 2011 C63
thanks.
Old 08-17-2014, 06:07 PM
  #154
Valvestud's Avatar
US 2011 C63
thanks.
Your engine serial number is 156985 60 065868 and is not affected.
Regards,
Joe
Old 08-22-2014, 02:26 AM
  #155
drmike5000's Avatar
2007 CLS63 AMG 030; 1970 Ford Mustang Coupe
Incidence?
Hello,
I have a 2007 CLS63, so I know I'm in the range. I've got about 66K miles. The car was shipped Oct. 2006, so less than 9K miles per year.
I've had a number of "check engine" issues over the past year, but the head bolt problem never came up- at least not with the dealer or private mechanic.
I had a fuel pump replaced- car smelled like gas, last year. I had a camshaft sensor replaced more than one year ago.
This year, I was told (check engine light) that my intake manifold gasket needed replacing, and there were three broken bolts- but I believe these were intake manifold bolts. I hit a pit of metal (fell off a truck?) on the freeway that came through my bottom grill- I don't know if this was related.
Most recently, I had the check engine issue. My car is currently at FJ Newport Beach. I'm told that I need a camshaft solenoid. My oil sub pump is leaking.
Anyway, are there any early signs of the head bolt issue? I've never had the coolant problem.
Do we know what the actual incidence is of head bolt failure, i.e., it's been X% of m156 engines thus far (give or take some variance)?
What I'm trying to determine is, should I hire a private mechanic to replace my head bolts preemptively, or should I just get rid of this car (it's cost me about $5K in repairs just this year)?
Thanks.
Otherwise, the car still drives well and has never stranded me, but the potential for this head bolt problem is bothering me since I'm sure it's very expensive.
Old 09-16-2014, 04:17 PM
  #156
[w]
[w]'s Avatar
none
hi, I'm looking at a 2010 but in Canada.
documentation i have says production date of 25 Jun 09
I'm guessing this is affected but would just like to confirm
WDDG F7HB 3AF3 72741
thanks
Old 09-16-2014, 06:00 PM
  #157
paraj415's Avatar
BMW M3 e46
WDDGJ7HB7EG173710
Can you tell me the option list please thx
Old 09-17-2014, 08:18 AM
  #158
Valvestud's Avatar
thanks
Confirmed.
Regards,
Joe
Old 09-17-2014, 08:19 AM
  #159
Valvestud's Avatar
Originally Posted by paraj415
WDDGJ7HB7EG173710
Here you go.
Regards,
Joe
File Type: pdf
Old 09-17-2014, 11:43 AM
  #160
[w]
[w]'s Avatar
none
thanks
Originally Posted by Valvestud
Confirmed.
Regards,
Joe
Thanks Valvestud. I should have asked for this the first time around, would it be possible to get the datacard for this VIN as well please?
Thanks!
Old 09-17-2014, 05:16 PM
  #161
Valvestud's Avatar
Thanks!
Attached.
Regards,
Joe
File Type: pdf
Old 09-18-2014, 01:44 PM
  #162
[w]
[w]'s Avatar
none
Attached.
Regards,
Joe
Many Thanks!
Old 09-18-2014, 03:30 PM
  #163
Hellbruegge's Avatar
E 63 AMG 2010
M 156 head bolts
Could you please confirm VIN WDDHF7HW4AA167210
Do you know exactly what was the issue, what was changed, is there some kind of service bulletin from Mercedes?
Ricardo
Hello,
As many of you know, I have been providing Datacard info to many members interested in their build sheet, or to verify engine serial number.
I received a PM from a member today who indicates he has a "late 2010 C63". The Datacard for the VIN he provided shows a delivery date of 11/24/2010. The Datacard indicates the engine number is over 4,000 engines beyond where the new head bolts were employed.
Since we've believed that all 2010 and older, and some 2011s were in the affected range, I'm confused about how this one could be outside the range. I did a search to find out which digit in the VIN corresponds to the model year, but had no luck getting a clear answer.
Anyone have any thoughts on all of this?
Thanks,
Joe
Old 10-01-2014, 07:23 PM
  #164
BobbyRitz's Avatar
2009 C63 AMG
First post. I have been reviewing the forum for a few weeks now. Great site with valuable information.
I'm looking at a 2009 C63 with 27,000 miles. It's in great shape, but I'm concerned about the headbolts issue. It has a one year CPO warranty, which I would extend by another year.
The VIN is WDDGF77X69F299745
I assume it's in the affected range. If so, should I reconsider purchasing this car, or is MB proactively handling this issue?
Best,
Rob
Old 10-01-2014, 09:08 PM
  #165
E 63 AMG 2010
E 63 AMG 2010
Ricardo
Old 10-02-2014, 07:04 AM
  #166
BobbyRitz's Avatar
2009 C63 AMG
I read headbolts threads for hours last night. No need to answer my question as to whether MB is doing anything proactively as they are not.
Interestingly, I noted the following within the Carfax of the car I'm looking at:
11/21/2011 12,959 Cooling system checked
Friendly Motor Cars
Wappingers Falls, NY
845-298-0600
friendly.mercedescenter.com
I am going to use the information I've learned here and have a serious discussion with the MB dealer. This car, in addition to being in the affected range, appears to fit the profile of low miles, infrequent use that I've read are more likely candidates for head bolt failure. I would like the options list if you would be so kind as to provide that for me, Joe.
Thanks,
Rob
Old 10-02-2014, 11:14 AM
  #167
Valvestud's Avatar
Best,
Rob
It's a 2009, so yes it is in the affected group. MB will do nothing until there's a failure.
Regards,
Joe
Old 10-02-2014, 11:19 AM
  #168
Valvestud's Avatar
Friendly Motor Cars
845-298-0600
Thanks,
Rob
Datacard attached. There's no known evidence that low miles, seldom used vehicles are more prone to failure. Latest discussion on another thread indicates failures may be more related to frequent cold-hot-cold cycles. This would make a low miles car a safer bet. Again, no hard evidence exists of anything related to when they can fail.
Regards,
Joe
File Type: pdf
Old 10-02-2014, 11:25 AM
  #169
Valvestud's Avatar
Ricardo
Your is a early 2010 and is affected. There is a TSB, but it is no longer accessible to the public. TSB L101.30-P-051567 is attached to link below.
https://mbworld.org/forums/c63-amg-w...-bolt-tsb.html
Old 10-02-2014, 11:27 AM
  #170
BobbyRitz's Avatar
2009 C63 AMG
Thanks Joe!
Best,
Rob
Old 10-02-2014, 08:27 PM
  #171
AMGJAY's Avatar
Ford Pinto
Can you check my vin please.
WDDHF7HB3BA429264
Thank you,
Jay
Old 10-02-2014, 10:20 PM
  #172
Valvestud's Avatar
WDDHF7HB3BA429264
Thank you,
Jay
Your car is not affected.
Regards,
Joe
Old 10-02-2014, 11:47 PM
  #173
Brent95M3's Avatar
2010 E63, 2007 997 Turbo
Can you check my vin please? WDDHF7HB7AA094265
Thanks.
Old 10-03-2014, 10:50 AM
  #174
Valvestud's Avatar
Thanks.
Once again, all 2010 and older, and some 2011, with M156 are affected.
Regards,
Joe
Old 10-04-2014, 04:09 PM
  #175
Francorchamps's Avatar
Would anyone be kind enough to check if the engine in this car is affected?
WDDHF7HB5BA429976
Thanks much for your time.
Regards,
Quick Reply: Head Bolt Affected VIN - 2010 & older, & early 2011s
