C63 AMG (W204) 2008 - 2015
OE MB Trickle Charger or can I use any charger?
Old Jan 6, 2014 | 01:06 AM
AMGer's Avatar
2010 C63 AMG
I'm looking to keep my battery charged with a battery charger/starter with 2 and 10 AMP charging options that I've always used before I got my C63. Typically I would use 2 AMPs trickle charging to keep my car batteries charged while I'm away for a long period of time but does MB cars require a special one made for these cars? I'm afraid the electronics are sensitive and screw something up. Anything special about the OE MB Trickle Charger?
https://www.mbpartsexpress.com/merce...e-charger.html
Thank you!
Old Jan 6, 2014 | 03:25 AM
bhamg's Avatar
C63 AMG
This is what you want…a low-output (.75 amp) float charger perfect for extended connection.
Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive
bhamg's Avatar
C63 AMG
duplicate deleted
Old Jan 6, 2014 | 04:38 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
I've got a C tek charger, with an attachment for charging through the cig lighter, but I don't think it's live in the C63 with the ignition off, so can't be done.
Consequently you guys must charge directly via leads to the battery in the boot? Do you leave the leads on & just connect the charger via the plug from these leads, or attach leads to the battery every time you charge it?
Do you have the boot shut during charging?
Cheers, Pickles.
Old Jan 6, 2014 | 05:07 PM
rage2's Avatar
C63 BS, GLA45
The OEM charger is a rebranded CTEK charger. I have the quick connector thing hooked up to my battery for easy access.
Old Jan 6, 2014 | 05:10 PM
bhamg's Avatar
C63 AMG
^ Look under the hood, left side. You should see a ground post on the inside fender well and a vertical flat plate under a sliding red cover (positive connector). Those are your front battery terminals for purposes of charging.
