Carbonio ariboxes+Cold Air Intake= 22 WHP
lol yeah carbonio said "we have one left we can discount as a research system, cost is $x,xxx.xx, let me know". Was way less than $1900 + shipping I can tell you that, but at the end of the day, I knew they were merely aesthetic so I didn't bite.
it's a CF wrap
Oh, ohhhhh, I see. Can you take an up close pic of those vents? I think I really like what I see but can't tell at that distance. I just don't like the ones you can buy as they are just way overdone. I would like for just the actual fins themselves to be cf, wonder if I can have those made somewhere...?
Now that is a much more likely scenario and the one I have come to believe, although debunking myths and speaking the truth is unfortunately rather unpopular in places like these (i.e. automotive forums) where there is a lot of money to be made from snake oil and wishful thinking. People need to believe that they are getting something other than a cosmetic upgrade for their $2.5K that no one except for them is even going to see and can actually rob their engines of power at lower RPMs.
Airboxes nowadays are designed as resonant systems, just like loudspeaker enclosures. You have to take into account compressible fluid mechanics and resonance patterns and optimize the design with CFD modelling, which is what MB does. I have yet to hear of any aftermarket tuner than does this. Unless you properly design the airbox to cancel out and minimize pressure changes at the intake port during the intake stroke (when you have low pressure as the engine sucks in air) and the compression/power/exhaust strokes (normal atmospheric pressure) and then tune the engine (adjust the fuel) for the amount of air you're delivering, you're not creating any additional power and quite possibly doing just the opposite in the mid-band. If your engine note changes and gets louder as a result of your aftermarket airbox, it's because you now have larger pressure changes (and thus sound) in the airbox as a result and you are making it more difficult for the engine to suck in the optimum amount of air. That results in a net power loss, not gain. You may gain 2-3 HP at the top end, but it comes at the expense of losing power in the midrange.
As for the material they're made of, the higher the thermal insulation of the airbox the less the engine will heat up the air as it goes in (denser air = more power). If it was structurally and mechanically feasible, an airbox made of styrofoam or porcelain would provide better thermal insulation and more gains than the same airbox made from plastics. CF is even worse as it generally has very high thermal conductivity.
So - could someone "in the know" please explain to me where these alleged power gains are coming from? I would really love to hear it.
<end rant>
<end rant>
#32
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
It sounds like it makes sense, but then again my friend posted a video in comparison.
In Living Color - YouTube
If what you're saying is that you don't understand what I am writing about, that's perfectly fine, but just because something is way too much for you to comprehend doesn't make it untrue or gibberish. It merely reflects your lack of knowledge on the subject. You might want to Google "airbox design" and see what comes up.
If that's not what you are implying, then I am the one at a loss as I have no idea what it is that you're trying to say. You might want to try using simpler, shorter words as communication is obviously not your strong suit either.
#33
2005 E55 AMG, 1991 MR2
Its definitely easy to gain a few top end hp while losing low and mid range torque and slightly reducing the "area under the curve". A lot of mods come with trade off's that are often not considered. It's not hard to go backwards.
#34
clichere1,
Bro, How ya been. its been a while since I heard from you. I hope you are well. I did not know you were back in Qatar.
A few things need to be noted. First of all, I know the dyno shop that you went to in Salwa Road, Motorsports which belongs to Mohamaed Albasti. Its the most inacurrate dyno in Qatar, end of story, dont let him fool you and tell you otherwise. Mohamad is known to fluctuate corrections and load factors and minipulate his customers.
Second, I have the carbonio intake installed on MY SL63 for almost 4 years now as everybody propabley knows. You will not gain 22whp from the carbonio and the intake. Trust me bro, that is impossible. The fact that you took the car on another day, is evident enough the operater changed the load and correction factors.
If you really want to know how much you gained, give me a call this weekend. I'll be going to a much better dyno (Dynojet 224) and I'll take you with me. We will swap your stock airboxes and stock intake and run the dyno. Afterwards, we will install back your carbonio and JLM intake and we will see the gains on the same correction, same day, and same conditions.
I'll tell you right now, the gains are going to be within 5-10whp max
Most of the gains come from removing the charcoal elements which are restrective and freeing up the air inlets and removing the resrictive housing. The Carbonio doesnt come with these things and thats why you see the gains on US spec cars. However, if you had installed the airboxes that are from the rest of the world "ROW' that come without thses restrictions from factory (like the cars from "gulf spec"). You will see similar gains. I can also show you this on the dyno
Call me and I can take you with me this Saturday bro
#35
clichere1,
#36
Man looking at your engine bay the amount of dust/sand you guys accumulate other there !! I would be cleaning my engine everyday like a paranoid .
#37
Hi gents. Thank you for your support. Our AMG 63 intake employes a few ideas that I'd like to share with you today.
We designed the AMG 63 intake to fit just like the factory intake system and engine cover. We realize that many AMG owners want to preserve the OEM look but also want to enhance their engine compartment. We believe that our intake accomplishes that objective.
Our intake eliminates the need for carbon air filters, which helps increase airflow into the engine. Those carbon air filters also act as sound absorbers in the intake system.
The AMG63 engine takes up quite a bit of space under the hood. We have eliminated all restrictions in the air intake and increased the height and width of our carbon fiber airboxes which creates a larger plenum and we include genuine K&N air filters with our AMG intake systems.
From our dyno runs we have determined that our AMG63 intake produces 18hp.
Please keep in mind that there are many variables that can affect how an engine performs (ie. altitude, humidity, fuel, ECU programming, etc.) and there is no "absolute standard". It is possible that different vehicles will respond differently to any aftermarket product.
We realize that our products do not cater to everyone, but we hope that our customers are satisfied with the work and quality that goes into each and every product we sell.
I would also like to add that if you have any questions about our products please feel free to contact us, you can find all of our contact info at www.carbonio.com
#40
One has to subtract the 10hp gained from just upgraded filters and carbon delete. The real gains are closer to 10hp once you subtract out the carbon filter delete and upgraded air filters.
Once you do that the gains aren't that impressive.... But it sure does look pretty!
#41
#42
I wish the Renntech one didn't come with the tax.
#43
The Porsche 928 and some MB & BMW cars have used venturi tubes for a long time to feed the airbox.
P.S. A couple of discussions are at http://forums.rennlist.com/rennforum...advantage.html and http://www.bimmerfest.com/forums/arc.../t-672474.html.
