C63 AMG (W204) 2008 - 2015
Anyone with a Eurocharged tune get the latest transmission software update from MB?
Old Apr 21, 2014 | 09:03 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by Autosport7
So if you have the updated TCU map installed by the dealer, as long as the dealer doesn't rewrite the ECU mapping, you shouldn't have to reinstall the EC tune correct?
If the dealer does overwrite your EC ECU tune and applies the TCU update, when you reinstall the EC tune, it will not affect the updated TCU map right?
Correct...
IF the dealer does update your ECU software to a newer version, you will need to send us that file and have a new one created to store on the mygenious. If you try to write the tune file that is made for a different version of the software (older) you risk the car not being able to start and will have to send us the ecu to fix. (downtime)
Old Apr 21, 2014 | 03:50 PM
oneandonly5680's Avatar
2010 C63 AMG Sedan
Originally Posted by loungn14
Correct...
Ok so I will just verify with the dealer what they have to do in order to update the software then and go from there.
thanks,
Old May 2, 2014 | 10:02 PM
Dr Chill's Avatar
Porcelain Bus
A better question is: If we get the car back from the dealer after the TCU flash, how can we tell if they reflashed the car with an updated ECU tune or if it still has the Eurocharged tune? Just by the perceived difference in power delivery or can we use the mygenius device to find out? After all it will be hard to tell with the tranny behaving differently.
And second question, isn't it advisable to go back to the stock tune before bringing it to the dealer to potentially avoid possible warranty flagging? Awaiting EC's reply.
