C63 AMG (W204) 2008 - 2015
Wavetrac being installed
Old 05-25-2014, 12:05 AM
Kriston's Avatar
C63 AMG
Gents,
Out of curiosity, how many hrs for typical install of the LSD?
Old 05-25-2014, 01:10 AM
avery.whss's Avatar
S550 on order
Originally Posted by Kriston
Gents,
i'm getting a wavetrac lsd soon and the mechanic says 8.2 hours to installs it
Old 05-25-2014, 01:13 AM
zibby43's Avatar
'20 GLC300 SUV
Jesus Christo . . .
Cha-ching.
Old 05-25-2014, 01:23 AM
avery.whss's Avatar
S550 on order
Originally Posted by zibby43
Jesus Christo . . .
Cha-ching.
he said $600-700 labour..not to bad?
also Ingenieur did you need these parts for the install?
Right and left carrier bearings
Axle shaft seal rings
Old 05-25-2014, 09:39 AM
Ingenieur's Avatar
C63 AMG
My bearings were reused
Only had 20 k miles on them
The seals were replaced
Old 05-25-2014, 10:26 AM
Jasonoff's Avatar
Received 1,587 Likes on 935 Posts
2010 C63 AMG
Jesus Christo . . .
Cha-ching.
It's an involved install...
Old 05-25-2014, 01:44 PM
  #32
nkc
nkc's Avatar
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
@jasonoff, is it something one can do as a DIY and if u have an oem lsd, any real benefit doing this?
thank you
Old 05-25-2014, 03:44 PM
  #33
Jasonoff's Avatar
2010 C63 AMG
No this is not a run of the mill DIY. You need very specific tools to swap the ring gear and bearings over.
I didn't have an OEM LSD so I'm not sure. Wavetrac is mechanical where OEM is clutch. They behave differently and have different locking percentages (Wavetrack is also adjustable).
Old 05-25-2014, 03:53 PM
  #34
Ingenieur's Avatar
C63 AMG
I'm pretty handy; brake jobs, clutches, valve adjustment, etc
Over 30 years shadetree experience on BMW's, Porsches, etc
This was more than I wanted to tackle
Tools
Some say a press
A lift
But most importantly the knowledge base to shim /set it up properly
It was the best money I've spent on a 'mod'
Imho in this case a 'must'
Old 05-25-2014, 03:54 PM
  #35
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by Ingenieur
As I type this
Looked at having AGC do it but it was just too far
A good deal but when mileage, time , hotel factored in didn't work out
Found a place Sheptrans 3 hours from home
A good deal also but more importantly seems like a quality operation
Specializes in trannys , diffs & xfer cases
A real organized and well equipped operation
Has a rep for gtr and evo work
And the owner is an AMG guy
06 e55 modded I think
12 e63 with ceramics
And a 8.5 sec 175 mph gtr
He was disappointed it didnt do 185
He showed me the diff, a real nice piece of engineering
In fact he bought one for his e55
I have a high degree of confidence that it will done right
Shep is one of the top notch guys in the Evo and DSM community for years. Like Dave Buschur (Buschur Racing)He is well proven you won't go wrong!! He has a ton of videos on you tube and is known everywhere!!
Old 05-25-2014, 03:57 PM
  #36
ProjectC55's Avatar
Originally Posted by Tal@ACGAutomotive
John Shepherd is the man and has a fantastic facility.
Only guy we trust with our GTR Trans builds
I wouldn't hesitate to let him do my diff either.
AMEN!!!!!
Old 05-25-2014, 04:03 PM
  #37
Jasonoff's Avatar
2010 C63 AMG
Tools
Some say a press
A lift
You need a bearing puller and press.
A bearing cone heater (may be able to get away with an oven)
A lift would be handy but un-necessary. Pulled my pumpkin on the garage floor.
There are no shims.
Old 05-25-2014, 09:42 PM
  #38
OlegKouz's Avatar
2012 Diamond White C63 Coupe
I have no factory LSD (non p31) and think this has to be the next mod!
Old 05-25-2014, 10:33 PM
  #39
whoover's Avatar
'19 E63S sedan
There are no shims.
How is the ring and pinion spacing set without shims? Last time I did one (a Porsche so it was different) checking the mesh pattern and redoing the spacing was critical for silent running. How does MB do this?
Old 05-26-2014, 08:06 AM
  #40
Jasonoff's Avatar
2010 C63 AMG
Maybe you could shim the ring gear if it's out of spec.
My factory backlash was within spec and still within spec with the Wavetrack.
Old 05-26-2014, 10:08 AM
  #41
Ingenieur's Avatar
C63 AMG
John had shims just in case but didn't need them
The only hiccup was some components use an external 12 point fastener and he didn't have the tools
As soon as he realized it the Cornwall tool guy pulled in
Problem solved
Old 05-26-2014, 11:28 AM
  #42
Jasonoff's Avatar
2010 C63 AMG
Problem solved
So he would have shimmed the ring gear if the backlash was out of spec?
Old 05-26-2014, 11:39 AM
  #43
Ingenieur's Avatar
C63 AMG
I have no idea what they were for
I thought they were used to center the carrier?
Establish the relationship to the pinion?
But really don't know
Old 05-26-2014, 12:52 PM
  #44
Jasonoff's Avatar
2010 C63 AMG
Nope, it's fixed in the housing. I didn't see any way to shim the pinion depth like you can with some other differentials.
Just cross your fingers
Old 05-26-2014, 01:09 PM
  #45
Ingenieur's Avatar
C63 AMG
Not pinion depth
Carrier side to side
Wavetrac sent him the shims
They have a MB pn
The also show on the mb parts program
I have more confidence in sheptrans than I do you
Infinitely
They were on the order of 100 ths of an inch
Similar set-up as in the link
Diagram item 17 mid way down
http://www.peachparts.com/shopforum/diesel-discussion/344307-w201-differential-refresh-thread-3.html
Old 05-26-2014, 01:57 PM
  #46
avery.whss's Avatar
S550 on order
Also if I have OEM LSD ...will I lose funcution with the "ESP - SPORT - OFF" button inside the car or will it still work like the stock one?
Old 05-26-2014, 02:01 PM
  #47
Ingenieur's Avatar
C63 AMG
Shouldn't make a difference
Both are mechanical
Imo if I had an oem lsd I'm not sure I'd spend the money
Old 05-26-2014, 02:21 PM
  #48
Manofsteelpt's Avatar
S63
Does the LSD help with straight line acceleration (ie a drag strip) or just on curvy roads/track?
Old 05-26-2014, 02:24 PM
  #49
avery.whss's Avatar
S550 on order
Both are mechanical
with wavetrac when you "WOT" it...does it hookup or does it cut power for 2-3 seconds? If it hooks up without losing traction..it's better then the OEM OEM LSD cuts power no matter what if you WOT it even with brand new tires ..unless you turn ESP OFF but you run the risk of doing donuts then
  #50
whoover's Avatar
'19 E63S sedan
Works the same.
Quick Reply: Wavetrac being installed
