Check engine Light Help!
I have the following CEL codes
P0017
-Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
P0171
-System Too Lean (Bank 1)
P0300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
Car was running really erratically last night and had no power with really rough vibration all around. Once I got home I tried to diagnose the issue and when I place my hand near the exhaust, only the driver side of the car was emitting warm exhaust while the passenger side was cold air.
Today I took out all the sparkplugs and heres a picture of them:
The left sparkplugs are cylinders 5,6,7,8 and the right side is 1,2,3,4
Does anyone have any possible ideas on how to fix this? I've heard the cam sensor sometimes do break and I don't know if it's the intake or exhaust one to replace.
Thanks,
The sensor would be on the cam adjuster. The adjuster unbolts from the front to remove it. There is a seal that you may need to replace.
It might be the adjuster itself that is toast and the sensor is reading right.
I would say A is intake B exhaust, Roadtalon would know for sure.
heres a visual... camshaft B is going to right where the cap/lid of the power steering reservoir is
I saw this post last night and was going to put some rude comment up about people being way in over their head, but i decided to just sit back and see what everyone else was going to reply with. Since you pm'd me I'll play nice
that and i like your silly signature dog thing.
https://mbworld.org/forums/c63-amg-w...d-folks-2.html
found a thread with similar problem as mine, i'll try o2 sensor next.
http://www.zoro.com/g/00044724/k-G13...FSxo7AodJAsAiw
something like this? and maybe a ratched that can index
http://www.powersportsplace.com/part...FW4Q7AodQxgAtg
i just found the easiest pictures to show what im talking about. I dont own those exact products, just similar. Those are for examples.
