C63 AMG (W204) 2008 - 2015
High-pitched whining noise from engine!!!
Old May 24, 2015 | 03:26 PM
TaxmanHog's Avatar
2017 E300 Luxury Package 2
Here is how ours sounded before the fix:
Old May 24, 2015 | 03:27 PM
TaxmanHog's Avatar
What it sounds like with new pump.
Old Jul 23, 2015 | 02:55 PM
tri-color's Avatar
Mercedes benz
Originally Posted by uc63ry
https://www.youtube.com/watch?v=IdVZ...ature=youtu.be
(Turn up the volume. iPhone 6 didn't capture the sound that well.)
Is this the noise you are talking about?
I'm currently experiencing the same problem too (no CEL).
Has anyone solved this problem yet?
+ I also get abnormal sound when accelerating.
uc63ry, the sound is similar, and it does intensify when accelerating just like yours, but mine is more high pitched. I will try to record in the next days.
Old Jul 23, 2015 | 03:16 PM
Anatoli's Avatar
E500 estate
Is it like that?
Old Jul 23, 2015 | 04:10 PM
tri-color's Avatar
Mercedes benz
Originally Posted by Anatoli
Is it like that?
[C63 AMG motor sound without whistler - YouTube[/url]
[C63 AMG motor sound with whistler - YouTube[/url]
Hey! Your sound is definitely a family member of mine, yours is very high pitched, while mine is more hollow, but the character seems the same. What was causing that whistling and how did you resolve it?
Old Aug 2, 2015 | 12:51 PM
Ookami's Avatar
1997 C230
Originally Posted by AMGPower88
So my friend has a 2009 C63 with 12,000 miles on it, he just recently purchased the car last month. Last week, he got Service A completed on the car and after a few days, he started up the car at cold start-up and there was a high-pitched whining noise coming from the engine, definitely not normal. He told me the car still drives fine and everything and that noise goes away after about 20 seconds after start-up. After a few hours, the check engine light came on.. So he took the car back to the dealership and telling them about that noise, kind of hinting that they caused this issue since they just serviced the car. They ran a diagnostics and they said it was throwing some very odd codes and they werent able to pinpoint the issue.
They told my friend that it had something to do with a start-up code for the engine and that they had re-programmed everything on the engine and restarted the computer. The service advisor told my friend that judging by the sound my friend described, it could be a bad air pump? But he wasnt sure, so all they did was re-program everything and the check engine light was gone. They didnt charge my friend anything and then this morning that high-pitched whine came back, but so far no check engine light on. Also if he turns off the engine and starts it again, there is no high-pitched noise, it only happens at cold start-up in the morning. So my friend is going to record that sound tomorrow morning and take it to the dealership so that they can hopefully hear it and determine what it is.
Do any of you guys have any idea what it could be? Any help would be greatly appreciated! My buddy is very worried. Thanks
This happened to me also. I always hear that sound on a cold start. It lasts about the same time you mentioned. Usually I dont drive off until the sound goes off. Well one day I decided to not wait and drive off. At the stop light, I could hear the sound going off and on. Like its trying to start and then go off, the idle was being affected too. Eventually it stopped and was normal since. Again I didnt wait for the sound to stop upon start up and I just drove off. Again at the stop light, same thing happened, this time, the check engine light came on. From what I have read, it looks like the secondary air injection pump making the noise. The thing is, I cant believe I would have to actually wait for it to turn off before driving off? because I didnt and now I have the check engine light on. I will be going to a mechanic to trouble shoot it.
Old Sep 22, 2015 | 08:31 AM
  #32
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Might as well bump this thread as well.
AMG893/Anatoli, did you get this sorted? I have the same sound on cold. Will hear it come on then off, BUT when it's hot, it's on constantly.
Below is after a commute home with it hot.
Old Sep 22, 2015 | 09:15 PM
  #33
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
What was the whistling sound for you?
Old Sep 23, 2015 | 12:50 AM
  #34
AMG893's Avatar
2010 C63 Estate
Hi Jasonoff,
I did reply to your PM. I didnt have any problematic sound. I only posted my vid as am example of a normal cold start sound
Old Sep 23, 2015 | 08:36 AM
  #35
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by AMG893
Hi Jasonoff,
Are you sure? Nothing in my inbox
You posted the vid below with the vacuum cleaner sound mentioned. It's too difficult to tell if it's the same sound. I don't think it is after having a good listen to mine yesterday.
Guys, i took a quick vid of my car on cold start this morning.
Is this the sound you describe? If so, this same sound happens on my ML63 and E63 also.
Cold Start Example - YouTube
Old Sep 26, 2015 | 11:27 AM
  #36
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Re-torqued all the IM bolts, noise still exists. Seems to be coming from the pass side near the middle of the IM.
Maybe the TB housing seal inside the IM?
Old Oct 30, 2016 | 01:58 PM
  #37
samrogersc63's Avatar
w206 c63
Same issue
High Pitched Sound - YouTube
i have the exact same noise did you manage to resolve the problem? If so what was it? Thanks
Old Oct 30, 2016 | 04:08 PM
  #38
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It was either the IM gasket or PCV.
https://mbworld.org/forums/c63-amg-w...valve-diy.html
Old Dec 10, 2016 | 07:30 AM
  #39
Drokas's Avatar
Mercedes benz Ml63 AMG
Please Help!!! Engine Buzzing sound
Hi Guys,
i Have bought a ml63 from Mercedes about a month ago and has always made a Buzzing sound, I took the car to Mercedes and they said the sound is normal, The sound is really annoying, to be honest it takes the fun out of driving it. Please Help!!Any Ideas
Please Have a look at the you tube video, don't know how to upload it
Old Dec 10, 2016 | 09:50 AM
  #40
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Drokas
Hi Guys,
Normal for an air leak maybe.
That sound is NOT normal. Likely either PCV, IM gasket, or both. I would force them to change both it since it should have been addressed before your purchase.
Old Dec 10, 2016 | 06:30 PM
  #41
Drokas's Avatar
The sound is not there when cold but gradually gets louder when warmed up, I will Take it Back to Mercedes to have it looked at again.Thank you
Old Dec 10, 2016 | 06:40 PM
  #42
chrisridebike8's Avatar
'10 C63
Yeah. That sounds like the IM gasket.
Old Dec 11, 2016 | 07:28 PM
  #43
Drokas's Avatar
Quick Update,
I took my car to mercedes benz, they said it is a noisy air pump, So i booked it in to get fixed on friday, will keep you posted.
Old Dec 13, 2016 | 10:32 PM
  #44
m3driver's Avatar
09 C63, 04 CTS-V (just sold), 06 325, 15 500e, 96 NPR, 05 C172
Quick Update,
i had the exact same sound. 3 of the 10 intake manifold bolts weren't even finger tight. Pretty much just wiggling about. (it was throwing bank 1 lean codes too) Stupid aluminum bolts. I tightened them up and everything was fine for about 400 miles and now it's doing it again. I have new bolts now, just need to find some time and a place to replace them.
Marco
Old Dec 14, 2016 | 07:44 AM
  #45
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Marco
I hope you're planning on replacing the gasket as well.
Old Dec 14, 2016 | 10:52 PM
  #46
Drokas's Avatar
So I took my car to MB they had a look at it and the said the air pump was fine, the problem was leaking intake manifold gasket its getting changed now, hopefully it will be fixed!!
Thank you guys
Old Dec 22, 2016 | 06:26 AM
  #47
Drokas's Avatar
Engine light on (PO10B)
Hi Guys,
I recently got my intake manifold gasket done and a day later the engine light comes on, i took it to a local shop and the error came up as (The measured left air mass is implausible compared to the position of the throttle valves(p010B)
Please help !!
