Installed Eurocharged V5 Help!!
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Hmmmm....Something is not adding up, as I already stated car should have trapped faster regardless of E/T. Was there a huge head or tail wind one day? Same track, similar temps, weather, DA and over all conditions should have been running quicker with the tune.
This is a perfect example of why I always like to get a baseline dyno figure before starting on mods. It is nice to be able to see how much power a specific mod netted you.
The good news is Eurocharged is a reputable tuner and will get to the bottom of it if there is any issue with the tune. You are in good hands.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
It's kinda difficult to tell, unless you have had enough seat time with your car in stock form. But, a few WOT runs would be able to confirm so difference. Plus, the increased throttle response and harder shifts.
#32
Definitely could tell. Especially nonPP to tune.
#34
Anyway, this should be a simple case of the car simply wasn't tuned properly.
#36
Well...does it go 280km an hour in about <15 seconds? If so..it's tuned..Not sure why you wouldn't just use the handheld and tune it yourself..takes <3 minutes
Downshifts will sound like this also on V5, also theres 0 wait time, the second it's done writting is when it's tuned.
#37
Avery. I'm uh, going to need a minute.
Do you have headers?
#38
#40
depends on the road/conditions/how you start...i hit 200km in 8-9 seconds ..i've hit just under 300 in around 20-ish, mine isn't stock though ..i should have said <20 seconds..would be more realistic for most
#41
I had the exact same problem my 13 coupe. I took it to a very high end tuner near me just to use the dyno because I really couldn't feel a difference. Guess what, no difference with tune or without except the speed limiter had been removed. Talked to eurocharged for hours, refreshed 10 times, shop tried flashing. Always seemed like it took but never changed the ecu.
Eurocharged admitted there a certain cars that for some reason will not program. They gave up and we're nice enough to give me my money back. Ended up taking it to renntech. They programmed it out of the car and dyno tuned it with no problem. Looks like u have one like me that doesn't like the handheld.
#43
^ It just has to. That is loud, sexy, and I must have it.
#45
Trust me a tune only C is not going to go 175mph in 15 seconds, hell no C with any amount of mods will go 175 in 15 seconds. I was running both my C(790whp) and SLS(700whp), both of which are supercharged at a 1/2 mile airstrip event this weekend and my C was only going 158 in about 15 seconds and my SLS was only doing 169 in about 14 seconds.
#46
^ Haha "only 169"
#47
Those cars couldn't even get out of their own way
Rolling road blocks
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#48
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
I ran my 790whp Weistec Supercharged C BS in the Michigan Mile last year and went 314KmPH/194mph and it took well over 20 seconds. I will look on You Tube for the video.
A tune and header only C63 would take probably close to 30 seconds to run a 1/2 mile
#49
And start timing at 100 mph???
Lol
#50
I could not find the video of my car at the Michigan Mile but I beat this GT-R, he took 4th place and I took 3rd. In this video he goes 302KmPH which is about 187mph and it took him about 26 seconds from start cones to finish cones. So no way is a tune only C63 doing it in 20ish seconds.
