Evosport phenolic heat spacers?
Did you do a search in here?
I think I remember seeing an old thread about it.
Benefit are supposed to be for heat dissipation. Since evosport is not in business anymore I don't know if these are still available for sales
2010 C63 P31 AMG
Yea I've seen the thread but don't know very many people running it. I bot a new set from someone on ebay for $100 bucks a few days ago as a just in case I plan to use it.
No I haven't gone around to it yet and I'm not sure if I should do what he did. He also changed the screws to steal ones since they are stock aluminum
2010 C63 P31 AMG
Just confirmed it has to be sandwiched now between two stock ones. Need to get 4 new ones. Not sure snout the screws. Most installs didn't say anything about changing them
Thanks for the heads up! 👍 I'll prolly get around to doing this soon and I'll let you know how it went!
The stock bolts are a 3 stage torque to yield. The bolts will need to be replaced. Not sure if the thicker spacer and extra gasket will require longer bolts or not.
Received 2,813 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Either of you guys install these phenolic spacers yet? And did you find a source? Thanks
Was hoping to install my renntech intake at the same time, but it's getting repaired. That will be installed next week, then il also hit the track.
Fitting intake spacers and weistec oil catch can.
So I picked up my car today. I installed the intake spacers. At the same time gave the inlet a manifold a good clean and removed all oils and carbon. I also fitted a weistec oil catch can and re set the ecu. So far I've only done about 40kms. Initially the car was very doughy and felt sluggish and as though it had lost power. How ever after driving it and the ecu adapting, well it now feel stronger then before how ever the *** dyno could be a placebo effect. I have only been able to go 1st 2nd and half of 3rd. It feels good though. Once I fit the renntech intake is will hit the track and hopefully the last dyno I had used.
Any of you guys have feedback on these spacers? Summer in Australia... surely it's known whether they make a difference or not?
I had them installed yesterday. Hard to say to be honest. Car has no hesitation as reported above. Basically they remove metal to metal contact from the IM and engine block. It's not a mod you would notice on a car with over 500 horsepower.
Thanks. So you're not doing before/after testing of your temps?
Anyone? RNS-11Z how do your temps look?
i have a set sitting underneath my desk waiting to be installed next time I get service done. I also want to get the proper bolts so they don't take it off and realize the old bolts wont work. Can someone tell me the type of bolts needed for this or can the old bolts be used? I understand with the extra gasket and these spacers, the factory bolts might be too short.
