Difference Between SportPlus And Manual.
Now I understand that with SportPlus, you get more faster and aggresive shifting, holds on to gears, blipping on downshift etc. That is all great and stuff. But what about Manual mode? Is if pretty much SportPlus mode but with full control of manual shifting from the driver?
What about putting the car in SportPlus and than using the paddlesto change gears? Is that affectively manual mode with full control of shifts?
Sorry for the cumbersone question but I am really not sure as to the concrete benefits and effects of the two modes and thought I would try and get some clarification. I really wonder if MB/AMG thought this through.
Where is manual mode you have full control of shifts, but is everything like shift speed, throttle sensitivity etc what it would be in sport+?
S+ is a regular automatic mode. The computer selects the gear.
In any automatic mode (C, S or S+) you can force the transmission to select the highest gear it will shift into (unless that gear would redline, in which case it overrides your limit and upshifts one gear). S+ will do this, but it's not a function of S+. C does it also.
The fast-shifting program is only selected in M and S+. Shifts are softer in C and S. S+ is much more like S than M. It's S with faster shifts and slightly more aggressive shift points.
