Installation instructions for MC Luftsrom front lip?
Does anyone know how the Mode Carbon Luftstrom front lip is installed? There are no tabs or holes or anything... does it use double side tape?
Thanks in advance,
-Adam
HTTPS://www.silicone depot.com
Lay ~1/4" bead about 1/2" away from the edge of the part. This reduces squeeze out and this is where most of the contact point between the splitter and bumper is anyway. (Also, the center OEM splitter needs to be removed).
I would suggest dry layup before applying sealant, that way you have an idea how to manipulate it to final fit. I used 3"inch 3M blue tape to hold the splitter in place while it cured. There sufficient tack time so no need to rush once the sealant and manipulating the part. Hope this helps.
