C63 AMG (W204) 2008 - 2015
MBH headers and Mid Section installed!!
Old Aug 20, 2014 | 02:41 AM
Mark63's Avatar
2009 C63 AMG, 2015 Toyota Tundra TRD PRO
So I finally had my headers and mid sections installed and completed today and I have to say the sound is the best.
It's nice and loud I love it.
BUT I realized that there isn't as much torque as before, why is that? Does anyone else notice this?
Also when I drive with my windows up and music off and hit bumps or go over a rough/bumpy road I hear some thumping noises like sometimes moving and hitting into something else, it's not metal on metal noises.
So for those of you who have MBH headers or have knowledge of my torque/thumping noise problems please help me out.
For those of you who aren't sure about MBH headers sounds, trust me you'll love them if you want to be loud all the time.
Old Aug 20, 2014 | 07:17 AM
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Which ECU tune are you running with the headers?
Old Aug 20, 2014 | 09:13 AM
mr747's Avatar
c63
I think u need a tune
Your car will go like crap with a standard tune with headers and mid pipes
Old Aug 20, 2014 | 10:06 AM
Mort's Avatar
The question about the tune is a good one to start. Also the headers have two inch primaries which might steal a little low end torque.
Did you reinstall the cross brace that goes under the mid pipe before the resonator?
Old Aug 20, 2014 | 08:45 PM
Overspooled's Avatar
Slow Vehicle
My exhaust was welded in a bad angle when I removed my cats and resonators where it would hit the cross brace on big bumps. I haven't gotten the time to fix it but i'm thinking that could be OP's problem.
Old Aug 20, 2014 | 09:50 PM
glennhl's Avatar
2011 C63
Wish you had done a before and after dyno pulls. I put long tube headers on my last two performance cars and I also thought I lost low end torque. But after looking at the dyno pulls, in both cases I had more torque from idle to redline. What I think happens is since you are now making more power, it makes the lower rpm's seem weak by comparison.
Old Aug 20, 2014 | 11:04 PM
bhamg's Avatar
C63 AMG
^ This. There is no loss of torque. I actually think it's because the new loudness (volume) makes one stomp on the throttle a little more gingerly initially, hence the feeling of less torque. It's not clear if you have a tune but if not, get one. It's a must with headers IMO.
Old Aug 20, 2014 | 11:59 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
OP surely has a tune otherwise he would complain of the CEL on his dash .
As for the low end torque are your midpipe straight or X ?
Old Aug 21, 2014 | 03:21 AM
Mark63's Avatar
I'm currently not running a tune, I can't decide between OE/EC or purchase the tune through MBH.
Old Aug 21, 2014 | 03:23 AM
Mark63's Avatar
I believe the cross brace was installed at the end before they dropped the car down.
Old Aug 21, 2014 | 03:27 AM
Mark63's Avatar
My check engine light is on as well but my mechanic told me it was because of the oxygen sensor because I have mid pipes(straight) that deleted the cats so hes going to install a spacer to by pass the sensor which should get rid of the check engine light.
Is that the check engine light you're referring to? or do the headers cause another CEL problem?
Old Aug 21, 2014 | 06:53 AM
mr747's Avatar
c63
^^^^ that's why ur car is running crap and feels weak
Pull the pin get a oe tune and some oxy sensors and your car will be a weapon
I raced a guy on the weekend with no tune just exhaust and it was not pretty for him
Just me man hurry up and get a tune
Old Aug 21, 2014 | 11:18 AM
Mort's Avatar
Yes get a tune. OE or EC is fine. I went with EC and it is working fine for me and I have MBH lth with catted mids and a x-pipe and stock cat back.
Check to see if the cross brace is there. If it is the exhaust is hitting it casing some noise/vibration. Just take it off or contact Mike about a drop brace he makes that will fit and may not rub or hit the exhaust on bumps.
Old Aug 21, 2014 | 09:00 PM
Mark63's Avatar
So all I have to do is get a tune with the new sensors and the CEL will go away and everything will be fine?
Old Aug 21, 2014 | 09:01 PM
Mark63's Avatar
Does your car make a foul/bad smell after you got the headers and mids?
Old Aug 21, 2014 | 09:18 PM
glennhl's Avatar
2011 C63
Smell is from not having cats.
Old Aug 21, 2014 | 11:35 PM
mr747's Avatar
c63
Yes mate you will be good to go try the tune first before buying oxy sensors
Old Aug 22, 2014 | 12:09 AM
CarHopper's Avatar
E63S | X5
As mentioned... Get a tune, 99% chance there is nothing wrong with your o2 sensors. Just needs the tune.
Also, I wouldn't dog the car much without the tune. Things could get... funky.
Old Aug 23, 2014 | 04:04 AM
Mark63's Avatar
What do you mean by dog the car too much? Should I not drive it without a tune? or you mean like rev it up and push the car?
Old Aug 23, 2014 | 10:09 AM
Autosport7's Avatar
C63 AMG
He means don't beat the hell out of your car atm as your ecu is not programmed to run the proper air to fuel ratios with an aftermarket exhaust and headers.
Get it tuned.
Old Aug 23, 2014 | 10:25 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
stupid post delete
Old Aug 23, 2014 | 05:14 PM
RW Carbon's Avatar
Former Vendor of MBWorld
Mercedes GT55 AMG
How about a video to hear this beast!
Old Aug 25, 2014 | 03:37 AM
Mark63's Avatar
No probably give me a few days I will put up a video!
Just waiting for my tune to get here.
