C63 AMG (W204) 2008 - 2015
Octane and Timing Effects...
Old Aug 25, 2014 | 08:54 PM
GRam's Avatar
2013 Ram 2500 Limited 2013 Harley CVO Road Glide
Just curious how running a lower than recommended octane effects timing/power output? I ask because I drove 350 miles to the nearest drag strip over the weekend to make a few passes.
I just updated to the V5 EC tune. Upon realizing I had not enough fuel to make the trip, I was forced to put about 25 litres (roughly half a tank) of 91/ethanol in, instead of the 94 non-ethanol I normally run.
Once at my destination, I added 30L of the 94, which left me at about 3/4 of a tank, and headed to the strip.
Had a gas, only had time to make 3 runs, best was 12.6 @ 112.5
Got me thinking, how much, if any, HP did I leave on the table? Buddy with a ZL1 Camaro says if his gets any little bit of knock sensor go off, then it retards timing until the car has it's battery disconnected for 24 hours.
I know doing that to ours will reset trans shift timing etc, but is the MB the same? Or once the knock sensors realize all is good with the fuel supply, it's just back to full steam ahead?
Thanks for taking the time to read the lengthy post..
Old Aug 25, 2014 | 09:27 PM
AMG6.3's Avatar
C63
Personally, if you mixed the two fuel octanes you were not probably leaving anything on the table regarding HP. At the track too many variables like having 3/4 tank of fuel vs 1/2 a tank, etc.
What was your 60 foot and your DA level?
Old Aug 25, 2014 | 10:34 PM
jmueller's Avatar
Jag F-Type V8
12.6 at 112.5 with a tune is questionable especially with the P31 package. What were your 60ft times? When I was doing 1.8 60ft times that's when I was in the 12.2s. It was very very very hot here in florida too.
Old Aug 25, 2014 | 11:30 PM
SROC276's Avatar
2010 C63 P31 AMG
I did a 12.56 @ 119mph and had an aweful 60ft at 2.3-2.5 running 19's. Probably bad technique. Running exhaust, shorty header and row boxes + tune. I have the p31 package too.
Old Aug 26, 2014 | 01:25 AM
Merc63's Avatar
C63 AMG
When I put 91 in mine I can feel it suck timing. (Blower)
After I refill with a full tank of 94, it's better within 20-40km.
Old Aug 26, 2014 | 06:30 AM
odonnks's Avatar
Ford Truck, 2014 C63 AMG 507
Regarding ignition timing, if the ECU knock sensor detects knock caused by low fuel quality the ignition timing is retarded. This reduces HP because ignition occurs closer to or after the piston reaches TDC.
Old Aug 26, 2014 | 08:08 AM
Autosport7's Avatar
C63 AMG
"TDC" - Top Dead Center
Somebody was bound to ask...
