C63 AMG (W204) 2008 - 2015
Wish me luck...
Old Sep 15, 2014 | 10:22 PM
ean's Avatar
ean
C63
Wish me luck...
Headed to the dyno tomorrow to get some numbers. Bringing along a few mods to do some before/after pulls. If he still has my graph ill try and overlay with a built 347 ls1.
Car is an '11 P31. Mods in the pic
-ROW airboxes
-AFE filters
-Eurocharged V5 tune
Results are in!
I was able to pull all of the runs together and I think this will give a little better insight into the mods. The biggest gains were throughout the powerband, not peak numbers.
First graph is a back to back run STOCK vs ROW. You can see power really isnt gained until the 2nd half of the RPM band. If you exclude the dip on the baseline Peak gains were around 8whp and 6tq
Second graph is is the last baseline (heat in engine) vs ROW & Tuned. You can see there was a substantial amount of tq added in the lower RPM range. Max gains here are around 25whp & 30tq
Lastly is the same graph with STD correction if you're into that sort of thing.
Old Sep 15, 2014 | 10:43 PM
Bardman's Avatar
C63 AMG 507 Edition
Nice one. I'm doing the same tomorrow.
I've got a 507 sedan and will be applying the Eurocharged V5 tune.
Procedure I'm planning to run is:
- Do up to 6 dyno runs stock to ensure stock ECU learning is optimised for Dyno
- Apply the tune
- Disconnect the battery and reconnect it (this is feedback from Eurocharged)
- Do up to 6 dyno runs with the tune
This should give us a decent comparison of the before and after.
Old Sep 15, 2014 | 10:54 PM
Conv_GSDriver's Avatar
'18 Audi A4
Cool, subscribed. Looking forward to the dyno charts.
Old Sep 15, 2014 | 11:09 PM
deeoh's Avatar
2011 C63 P31 2015 BMW X5M Schwarz Einhorn w/Bootmod3
Subscribed. Good luck!
Old Sep 15, 2014 | 11:10 PM
rentzington's Avatar
2010 C63 P30
- Apply the tune
Interesting, what was the reason for the battery disconnect?
Old Sep 15, 2014 | 11:17 PM
Bardman's Avatar
C63 AMG 507 Edition
This is the reason stated by EC:
"That's what I do here. The battery trick and the 4 runs after the flash are key... This is where it adapts."
Should mention, the suggestion is to have it disconnected for 10 minutes.
Old Sep 15, 2014 | 11:58 PM
snowmuch's Avatar
C63 AMG
Subbed
Old Sep 16, 2014 | 12:42 AM
papashango's Avatar
This and that.
Nice! Subscribed...curious to see the results.
Old Sep 16, 2014 | 12:50 AM
CarHopper's Avatar
E63S | X5
It's nice to see someone doing this the proper way. Before and after results, same day.
Good luck
Old Sep 16, 2014 | 06:33 AM
odonnks's Avatar
Ford Truck, 2014 C63 AMG 507
Subscribed !! Very interested in the results.
Old Sep 16, 2014 | 09:49 AM
AMG893's Avatar
2010 C63 Estate
Subbed!
Old Sep 16, 2014 | 10:15 AM
Kriston's Avatar
C63 AMG
Lets take some guesses at what the car will put down!
I Say Post tune + Filters - 395 WHP / 390 TQ.
Old Sep 16, 2014 | 11:24 AM
alexmtl's Avatar
2013 C63 coupe P31
Old Sep 16, 2014 | 11:45 AM
intence's Avatar
CLK63 AMG Black Series
430/380 book it
Old Sep 16, 2014 | 12:38 PM
Mort's Avatar
Good Luck
Old Sep 16, 2014 | 12:55 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
subscribed
Old Sep 16, 2014 | 01:34 PM
Razzy's Avatar
C63 AMG
Good luck
Old Sep 16, 2014 | 01:40 PM
edwardsflight33's Avatar
'16 CLS 63 S
Subbed! Definitely interested about the battery disconnect. Wonder if I should do it just because.
Old Sep 16, 2014 | 02:52 PM
ean's Avatar
ean
C63
The results are in!
I will wait to post up the graphs until I get home. The car was dynoed on a load bearing DynoJet 224xLC. The car was extremely consistent and the number went up with each mod.
One thing that is kind of bugging me is the speed limiter. After the Eurocharged v5 was applied, the car still appeared to be hitting the P31 (~174mph) speed limiter in 5th gear... because of that most of the pulls were done in 4th.
Old Sep 16, 2014 | 02:54 PM
odonnks's Avatar
Anxious and chomping at the bit here ....
Old Sep 16, 2014 | 03:00 PM
shivsiddh's Avatar
2012 C63 Amg
Cant wait to see the difference with the AFe filters and the Row Airboxes! Since I have already dyno'd with the v5 tune and need to decide if the filters and airboxes are worth investing in
Old Sep 16, 2014 | 03:30 PM
c63buckeye's Avatar
Lots
so what are the numbers? you are going to post each set of numbers incrementally?
thanks!
Old Sep 16, 2014 | 03:35 PM
Autosport7's Avatar
C63 AMG
SUBBED!
Old Sep 16, 2014 | 03:37 PM
Autosport7's Avatar
C63 AMG
Originally Posted by intence
430/380 book it
Hoping more of a 445/390 (prob dreaming, but cant one have a dream...)!
Old Sep 16, 2014 | 03:45 PM
Sidv22's Avatar
Audi A5 6MT, C63 AMG
subscribed! Thanks for doing this.
