C63 AMG (W204) 2008 - 2015
C63 LSD Quaife Installation
Old Oct 14, 2014 | 02:54 AM
tigerwoods2002's Avatar
C63 AMG Estate 2014
Hey guys,
I am looking for an LSD upgrade to my C63 estate.
As I am from Germany, I would go for the Quaife, as I don't know where to get a wavetrac over here...
Already talked to my MB Dealer for installation. They would like to see an installation guide for this thing.
Anyone could help me in this case? Can't find any info on the Quaife homepage if it is a direct replacement for the original differential, or if you have to fit it in there somehow...
Thanks a lot
Old Oct 15, 2014 | 01:47 AM
C63 AMG Estate 2014
Really absolutely noone?
Old Oct 15, 2014 | 02:08 AM
Falkaddoumi's Avatar
2014 C250 Sport
I believe from what I read on a site about these since I wanted to throw one on my c250 is that it is a direct replacement.
Old Oct 15, 2014 | 02:48 AM
sytfu_colan's Avatar
C63 Coupe
Slight grinding of the housing might be required, but other than that I believe it is a direct replacement.
Old Oct 15, 2014 | 03:02 AM
RuckinAMG's Avatar
C63
I'm no tech. but, I watched mine get put in and there was no grinding what so ever. Basically pulled your stock one out of the housing and put the Quaife in.
Old Oct 15, 2014 | 03:53 AM
bhamg's Avatar
C63 AMG
A former vendor here posted this:
There are absolutely no adjustments that can be made on the Quaife for backlash and pinion angle. There are no shims and no way to move the contact point of the ring and pinion. It is a direct bolt in.
It is the easiest, no brain install so I am sure the install was done correctly especially since you have done rears before.
Did you put new taper bearings in? What about the c-clips on the axles? I always use new bearings and always replace the c-clips since they are what holds your axle in the diff. Is your rear leaking at all?
