C63 AMG (W204) 2008 - 2015
Stalling and shaking
Old Dec 2, 2014 | 10:33 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
For some odd reason my car acted up the other night and stalled while the car was stopped and in reverse. I turned the car back on and everything was fine until I did a pull and on the third pull at WOT around 90mph the car started violently shaking and I had to slow down. Never experienced anything like this before other than the car stalling once before about 2 years ago. Anyone have any idea what's going on with my car?
Old Dec 2, 2014 | 10:34 PM
ChrisD63's Avatar
One thing I forgot to add is that I topped off the oil prior to the car stalling.
Old Dec 2, 2014 | 10:44 PM
avery.whss's Avatar
S550 on order
does it only happen after 4-5k RPM? or right off the bat? If it happens around 4-5k and feels like the car's gonna blow up, it's probably the fuel pumps (just went through this) intake manifold whistles ..it won't do much to the car, fuel pumps feel like it's about to explode though..my car had the exact thing happen, stalled a year ago, thought nothing off it, then one day it stalled again, then again, then shaked, then i beat on it and it CEL blinked and it ran like crap until I had it fixed 2 weeks ago
Old Dec 3, 2014 | 05:12 PM
ChrisD63's Avatar
It did probably happen around 4-5k given the speed and gear. How much did the fuel pump run you and how can I get this diagnosed?
Old Dec 3, 2014 | 05:26 PM
Ingenieur's Avatar
C63 AMG
Any codes?
Coolant loss?
After market tune?
Mods?
Old Dec 4, 2014 | 09:32 AM
ChrisD63's Avatar
Originally Posted by Ingenieur
Any codes?
Coolant loss?
After market tune?
Mods?
No CEL no codes no coolant loss. Just had to top off the engine oil a bit. OE tuned, Secondary cat and resonator delete.
Old Dec 4, 2014 | 10:50 AM
norb's Avatar
2009 C63 AMG
Might be overfilled oil.
Old Dec 4, 2014 | 10:53 AM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Sounds like you overfilled the oil. Evaculate the extra oil and the shaking should go away.
Old Dec 4, 2014 | 07:00 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I had both my fuel pumps replaced under warranty a long time ago, I believe they were around $900 each plus labor (and a month waiting for the parts to be shipped from Germany).. I did put close to 2000 miles on the loaner they gave me
Old Mar 26, 2022 | 03:40 AM
Endri55k's Avatar
Cls55
hello friend, i have a cls55 2006 have same symptoms like you,at higher speed when i punch the gas pedal i feel car stalls or the rpms dont go smooth like little shaking,maybe could be fuel pumps?i check the fuel pump was 7/05 date,i have a 82mm tb and a tune,i order 76mm pulley car make the symptom woors,
Old Mar 27, 2022 | 12:59 AM
roadtalontsi's Avatar
10 C six trizzle
Put your free Biden crack pipe down. thanks.
