C63 AMG (W204) 2008 - 2015
Tire size question
Old Dec 13, 2014 | 06:21 PM
Cee6three's Avatar
2013 C63 481 stock HP with LSD
Tire size question
I have stock 19" tires on my car 235/35/19 front and 255/30/19 rear...stock wheels
Will it be ok if I put on 255/35/19 front and 285/30/19 rear, like the black series? I'm pretty sure that it should be ok but I want to make sure of it....thanks in advance for your responses....
Old Dec 13, 2014 | 06:28 PM
rickclass's Avatar
2014 C63 AMG 507 Edition
don't recommend that combo, especially on stock wheels?
Old Dec 13, 2014 | 06:29 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Are u lowered? If yes, u might rub in the rear.
Old Dec 13, 2014 | 06:32 PM
Cee6three's Avatar
not lowered, stock height
Old Dec 13, 2014 | 06:39 PM
Cee6three's Avatar
What is your rationale for that?
Old Dec 13, 2014 | 06:44 PM
Roswell's Avatar
I guess rickclass meant the tire will be too wide for the width of the oem rims making the sidewalls bulgy & mushy which will affect handling.
Wider tires do improve traction on straight line though.
Old Dec 13, 2014 | 06:53 PM
rickclass's Avatar
BS stock wheels are bigger and different offsets...
19X9 ET25 and the rears are 19X9-1/2 ET47
Old Dec 13, 2014 | 06:54 PM
rickclass's Avatar
Old Dec 13, 2014 | 07:03 PM
Cee6three's Avatar
hmmm....my main reason for getting wider tires is the look, especially on the rears from behind....
Old Dec 13, 2014 | 07:11 PM
Roswell's Avatar
It will sure look beefy lol
But again, u might not like the handling while cornering. I would use 285 on x9.5 or x10 rims to be on the safe side. 275 on stock x9 is better & look nicer.
Old Dec 13, 2014 | 07:14 PM
looney100's Avatar
None
I'm siding with rickclass on this. I doubt tires more than an extra inch wide will fit the stock rims - check the manufacturers rim specs on whatever tire you're buying. You've also got about a 3% greater tire diameter, and the general rule of thumb is to stay within 2%.
Old Dec 13, 2014 | 07:33 PM
Mr Jones's Avatar
2013 C63 PP
If the OP is after a better look, especially from behind, maybe 275 and spacers would be the answer?
Old Dec 13, 2014 | 07:37 PM
Roswell's Avatar
19x9 with 275/30 & 10mm hubcentric spacers will rub over bumps & dips .. Not much options there.
Old Dec 13, 2014 | 10:12 PM
Mr Jones's Avatar
2013 C63 PP
265 with spacers? Or even OEM 255 with spacers?
Old Dec 13, 2014 | 10:18 PM
Roswell's Avatar
Yes, I'm running 255/30 with 10mm spacers lowered on h&r .. Very tight fit but no rubbing at all. 265/30 might clear depending on the tire brand (rounded or square sidewall).
I don't recommend using 5mm spacers as they don't come hubcentric which might creat vibrations.
Old Dec 13, 2014 | 10:23 PM
Cee6three's Avatar
I got a pair of cheap continental contisport 5p for cheap (285's)...I guess I should sell em....or maybe try to mount and see how it looks and decide then
Old Dec 13, 2014 | 11:08 PM
Roswell's Avatar
For sure, if u have them already nothing to lose to try them.
Old Dec 14, 2014 | 08:03 AM
hyperion667's Avatar
2012 CLS63
no 305's? bummer
Old Dec 14, 2014 | 12:03 PM
Overspooled's Avatar
Slow Vehicle
I put on 275's on the stock 18's and it looks great man! Ill be putting 245's in front next summer to get the same look as the rear. Looks nice and full but doesn't look ugly or ruin my handling. Oh and theres a lot more hooking now
Old Dec 15, 2014 | 01:23 PM
Cee6three's Avatar
My rears are 9.5?..i thought I had 9 all the way around....hmmm....im thinking 285s will be ok on 9.5....i guess ill find out once spring arrives
Old Dec 15, 2014 | 05:13 PM
Mort's Avatar
Stock wheels in 19" are 8" front and 9" rear. If your wheels are not these sizes then they are not stock wheels.
Old Dec 15, 2014 | 11:42 PM
Roswell's Avatar
^^ this
I got confused with the 9 inch all around.
Old Dec 16, 2014 | 08:19 AM
rickclass's Avatar
my quote was for the BS stock wheels....lol
