DSC off
btw with ESP off its still 10-15% on, you need to go into dyno mode to completely disable it to 0%
Usually it is faster to keep the ABS from kicking in as most ABS are not set up for ultimate lap times and will release the brakes a bit too much. But beating the ABS is no small feat. Many drivers over the years argued to be able to beat the ABS stopping distance very few can. Not only that, but without ABS it is really easy to flat spot the tires. But most of the great drivers cars have the ABS kicking in to the oblivious driver who just think he is good.
Out of a corner I believe some slip is faster than no slip. Of course, the smoke in the fenders type of wheelspin is not fast. There is a fine line between not enough slip and too much. It all depends on the speed/type and roughly maximizing overall speed.
The main reason I always turn my esp off on the track is because the stupid system won't let you throttle lift oversteer. So imagine you're in a bit too hot in a corner (in a student car) and you're washing wide a little. No big deal really. Now you just lift the throttle a bit to get the rear to slip and realign the car in a perfect line out of the corner and then the stupid $%&*&? system kicks in and puts your nose towards the Armco on the outside of the corner instead of nicely pointed towards the exit point! Yep. No biggie, didn't crash or anything. It's just that ESP will prevent some actions that could be done to help the car turn. The system always assume you want to go straight and acts accordingly.
It happened to me once some 7-8 years ago and never ever run with the ESP/DSC on ever again. Stupid stupid system on a race track. Okayish for the average joe on the street. I believe sport should be the default mode as it at least leave some space for line correction. Full off is good if you know how to drive.
