Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Install Compustar Remote Start
Step by step instructions for do-it-yourself repairs
Remote Start
2011 C63 AMG P31
Just get this..I have one and they are the same as Viper..rebranded..many installers available around Alberta...I also added the Drone so iphone starting and tracking works spanky
http://www.compustar.com/
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
So does this..it's integrated into your emergency button on the MB fob or I can use my iphone..either..just the fob has limited range
And to boot I use this "slice" which is ultra thin and two way and don't need the MB fob with/on me at all...for when I don't wish/have iphone or want faster response as the iphone can take 10-20 secs to react tot a command
http://www.compustar.com/remote-star...F-2W940-SS.php
I have the midcity unit on my W212 and had one on my W211 before that. They work great. A tap on the panic button and the car fires right up. If you want remote start on a Benz this is the way to go.
http://www.midcityengineering.com/smartkey-starter
I'm quite certain these (MidCity, Compustart, Viper..etal) all use the same base starter module (an adder module is required for keylessgo) then add modules to the base unit for
-security system add on
-drone (cell phone) add on
-different long range fobs from various companies
I don't know who designed that base unit..possibly MidCity Engineering..I did research it when I installed mine a year ago but no longer recall..
How much was that setup? Do you have the alarm as well or just remote start?
#32
Don't recall exactly but was like $1,500 installed (depends on which remote you select...which determines range)with Drone module (iphone)...regarding Drone you get first year service fee free (cell access) then it's something like $99 per year..and to get vehicle tracking and the other goodies like if you have your kids using the car you can set a fence and speed and be advised if the fence is broken or speed is over set limit...this is another cost of....guessing again,,,$120
Also forgot..no I didn't get the alarm
#34
One could likely install themselves but in the ML case a module is attached to the keylessgo module which is under the rear deck panel and a wire must be run to the module in the dash and why would I want to for go warranty or potential issues...some things best let the pros do
#35
The first one on my W211 without keyless was $950, and the installer didn't have a shop (mobile installer) so I watched him do the 1.5 hour install in a parking lot. Install consisted of removing lots of trim and dash to get access at wire harnesses; everything was plug-and-play no splicing of wires.
On my W212 with keyless go I went to a MB dealer 60 miles away that installed them. It was $1295 some additional cost for keyless and some additional dealer profit. This car is under warranty so I wanted the install on a MB invoice. The job may be slightly easier for the dealer because they have a special tool to remove the ignition module if necessary; which many installers don't.
#36
I have a unit like this on my car. It's offered through best buy. Though that's not where mine came from, but it's the best. Especially with my mods and how loud my car is it scares people who are standing next to the car when it starts.
#37
Do you recall what brand it was? Is there a link to it on Best Buy's website? Thanks!
#38
Data start.
http://m.bestbuy.com/m/e/search/searchresults.jsp?id1_hf_0=&-1.IFormSubmitListener-Header-HeaderSearch-searchForm=&st=remote+start+metcedes+c+class&cp=1& sp=&cba=true&scValue=Y&sc=Global&ev=event41%2Ceven t1&channel=Enhanced&search=true&usearch=yes&usc=Al l+Categories#searchresultsdiv
