Battery Replacement
Thanks in advanced!
At the end of the day I would stick with OEM and get a braille for a spare. They only cost $250 for a 18lbs not $2k! lol!
GL
I don't run my car but two or three times per month and never in the winter so I may give one a try in the spring.
Thanks in advanced!
Just checked - today's price is $189.99...ouch!
If so, disconnecting the rear main battery would not remove the 12VDC feed from the electronics.
Wifes' CLK63 Cab only has the engine compartment under the filter batt, no trunk battery as my E does and obviously no aux in the E.
We obviously live in the wrong part of the world, there are guys running 7 years old batteries that put out 11.7 volts
BUT, if you use the part finder on the Exide website it shows one is available. Will be swapping out my main battery tonight. Will report back
Also something to consider is the production date of the car. just because it's a 2010 doesnt mean it wasnt made in 2009. If its the original battery in the car you can look at the negative post. There should be some stamped numbers. The first set of numbers is the week number the second the year. so for example 32/10 would mean 32nd week of 2010.
Main battery replacement is simple. No need to maintain 12VDC. Just swap it out.
I have short drives to work which can prematurely kill a battery.
Doing a quick search, Walmart has the EverStart Maxx H8 listed for $123.13 with a 5 year warranty (3 year free replacement and 2 years pro-rated)
My batter is dead.
A couple of weeks ago, it sounded a little weak, so I knew it was only a matter of time. I was out of town for a week, and then returned yesterday. I started the car and it struggled to start but finally did. It sat for a week and it was getting colder so I thought to myself, I better buy a batter and change it this weekend.
Well, it is lunch time and the car won't start. Grrrr.
Question: Can I simply jump start it by hooking up jumper cables to the battery on the back? I just want to drive it home so that I can change the battery tonight.
Is it pretty simple to replace the battery?
Thanks!
Car jumped successfully. Got it home and changed the battery during my lunch break. The battery was $ 174 at O'Reilly's + tax. Everything seems to be working fine now.
Next thing to tackle is the stupid TPMS light...all my tires are fine on pressure but the light seems to stay on. I think the battery on one of the TPMS's has gone bad. The question is...which one.
