More Power? - Larger Throttle Bodies
In my quest of building a true bolt on N/A Beast, my focus has shifted to larger throttle bodies.
I have been researching for a few days, trying to find some circumstantial proof that the larger TB's actually provide a bump in HP / TQ. Theres very little information available on them and the effects of them on the C63.
I have already weighed the pro's and con's of adding a larger throttle body system to the car. I am also aware that the stock dual 72MM TB's flow at well over 1300 CFM. Which is more then enough for a full bolt on C63.
I am panning over the details on The Renntech Dual 82 MM Throttle bodies. Renntech claims 11WHP and 8 WTQ gains. I don't doubt Renntech's numbers, but I'm more curious about the driving dynamics of the car after.
From my general knowledge of increasing the size of the TB's, I should expect a quicker throttle response. Of course more airflow means more power / tq. But thats not all that I'm after.
I wanted to build a N/A beast because the love i have for this car in N/A form far outweighs me wanting more power. I am more focused on overall driving dynamics. I love the extremely linear power delivery the car has now.
Wanted your take on them? For an every day street car I would enjoy a quicker response. would you?
If any of you have experience with larger TB's on the M156, your input is most welcome.
http://www.renntechmercedes.com/www/node/192#
Cheers fellas,
There may vary well be a change to the throttle response though. That being said, if you are seeking are quicker more linear throttle response, I would work with someone like Eurocharged to customize the throttle on the tune. It is all fly by wire, so you should be able to make the throttle response exactly the way you want to be.
Good luck on on you endeavor to to achieve more naturally aspirated horsepower. I think it is truly a worthy cause, and I champion it. I just think throttle bodies are a dead end. Any meaningful increase will come from changes to the heads and camshafts otherwise you will be looking at increasing displacement or possibly increasing compression. AMG didn't leave a whole lot on the table other than bolt on exhaust improvements.
I have a custom tune on the car as well, as with many aftermarket tunes. The TB's on the car are mapped to open fully as opposed to 75% or so on the stock maps. from a tuning perspective I thin we have exhausted all other options.
Theres a part of me that wants to take the plunge, simply because of the allure behind the TB's. Its not a ventured path for many, theres that big question mark of what if this thing actually makes the power it states and also adds the benefit of a much quicker throttle response. Im attracted to the potential changes in the driving dynamics of the car. Hopefully it will be for the better.
if you do it for competition or for work and you get paid or win a nice trophy for that .15 sec improvement over stock then $5k might be worth it, but for many $5k to be a legend in your own mind isn't worth it.
I only bring up this perspective is because from experience I realized I paid so much for upgrades and after recently comparing to another c63, it's not like our car is so much faster like you're comparing a p31 package vs non-p31 or like a black series vs a stock c63.
in fact the more I think about it the more I believe MB did try to squeeze as much out of the M156 with the C63 BS anything more is pretty much just paper number and hardly good for actual day to day road use. if you want an edge, you're probably better off reducing weight on the car to get better power to weight ratio, and bang for the buck. you can drop 250pounds+ on this car and keep it streetable.
This is Great Insight, and I agree with you whole-heartedly, I ran with another C63 post header install on my car. The Other C63 was just tuned. From a dig to 150KM / Hour I was actually surprised how close he was still. I was ahead a half car length the whole time, only really started to pull ahead close to the 150KM mark. With exhaust work, I think the benefits come higher up in the gearing. Perhaps our top speeds would be much different.
I digress, I have already invested quite a bit into the C63, at this point I'm doing this more for the love of the platform and to explore the limits of the M156 in N/A form.
This is a great idea as well, to cut 250 LBS means removing seats etc. Not sure I want to go that far for a summer only daily driver.
I had a call into Renntech yesterday, im working with Mark over there (who is quite helpful actually) to see some real world results from these things. I will post up what findings I come across.
I managed to obtain the dyno graph from Renntech for the TB's. Blue curve is a stock C63 and the red curve is with the addition of the larger TB's.
So were looking at an 11WHP and 8 WTQ gain with factory exhausts and intakes.
Considering how well AMG designed these engines, the 11 WHP gain is huge considering Keith only managed to obtain 4-5 WHP with ported heads.
The plot thickens!
Im ... this close to pulling the trigger now.
The plot thickens!
not terrible gains at all, there isn't a ton of meat left on the bone when it comes to bolt on parts for these engines.
To me that's not enough gain to justify the cost, but if you are happy with the price I say go for it.
The plot thickens!
Saw u posted about Dads gains on the heads but i think the 5rw was with very different weather conditions. In this thread with similar condition pre install heads he gained almost 20rw on heads alone and if i remember correctly he gained another 25 with cams. https://mbworld.org/forums/c63-amg-w...omorrow-4.html
https://mbworld.org/forums/c63-amg-w...s-results.html
The plot thickens!
On a car with an aftermarket tune, the TBs will the 100% open and the larger Renntech TBs will yeild negligible gains.
The plot thickens!
https://mbworld.org/forums/c63-amg-w...ml#post3771052
Either way. The AR headers are MHP i just have the 1st version the 1 7/8th instead of 2in primary. This is proven on track that its better for NA set up then the 2in primary , i personally drove my car and my friends a former forum member on here he had MBH at that time and the low end tq wasn't there with the larger primarys. But for FI the guys with superchargers love the 2in .
Ive seen guys in Germany putting SLS intake manifolds on the m156 i guess its down to how much money you want to spend
