C63 AMG (W204) 2008 - 2015
Porterfield Brake Pad R4S From LPI Racing
Old Jan 13, 2015 | 03:45 PM
CSIKTY3's Avatar
2012 C63 Sedan - Mars Red on Red Pepper
Hi Guys,
I just ordered a set of Porterfield R4-S Brake Pads FROM LPI Racing in Livermore, CA. ASK FOR MONTE ANDERSON!
Front part number 1291 and rear part number 1373 .
Monty was great, didn't rush me on the the phone took the time to answer all my questions. They are located here in Northern California and I highly recommend them. Not to mentioned he has the best prices on these I could find.
Porterfield R4-S Carbon Kevlar Perf. Street Pad. AP 1291 R4-S
$262.95
Porterfield R4-S Carbon Kevlar Perf. Street Pad. AP 1373 R4-S
$113.95
Old Jan 13, 2015 | 10:25 PM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
Thanks. I need to get mine done and wanted to try these pads
Old Jan 14, 2015 | 09:31 AM
Clark Kent's Avatar
Veteran: Marine Corps
2010 C63
That's a great price. I ordered a set from topbrakes.com back in November.
Fronts: $270
Rears: $117
Price competition is good!
Old Jan 14, 2015 | 07:02 PM
mthis's Avatar
Anything W/4Wheels
Tnx for info i use does and they are great . Nice cheap price.
Old Jan 16, 2015 | 03:27 AM
AMG893's Avatar
2010 C63 Estate
Good to know
Old Feb 15, 2015 | 06:09 AM
Phorte's Avatar
2015 C63S
Cheers! Just ordered a full set to my US forwarding address!
Old Feb 17, 2015 | 12:15 AM
driftmotion's Avatar
C63
I have these on my car and love them!
Old Feb 17, 2015 | 07:17 AM
NickNZ's Avatar
2017 C63S Coupe
When changing from OEM to these brake pads, do you need any other parts? I think I remember reading something about some sensor that might need to be replaced as well? I could be wrong.
Old Feb 17, 2015 | 02:50 PM
solekeeper's Avatar
A V8
OP, these pads are regular pads (ie street use) right?
I don't need anything special, just something that dusts less.
Old Feb 17, 2015 | 02:58 PM
AMGPower88's Avatar
C63 AMG
Im about to get these installed this Friday.. Heard they're phenomenal pads.. Obviously much less dust than the oem pads, looking forward to getting these on asap. And yea they're for street use. Im pretty sure it's just a simple swap, nothing else needs to be added.
Old Feb 17, 2015 | 03:39 PM
tfthach13's Avatar
'09 C63
Fronts: $270
Rears: $117
I get my Porterfields from TopBrakes as well, but they take soooo long to ship the parts!
Good to know there's a local source!
Old Feb 17, 2015 | 03:43 PM
tfthach13's Avatar
'09 C63
Yup! Street usable, simple swap out, way less dust than OEM; just make sure to use a bit of copper anti-seize on the back plating for easy installation the next time.
The pads need a bit of heat in them to fully maximize the friction, but after that, you have tremendous stopping power!
Old Feb 17, 2015 | 03:46 PM
Clark Kent's Avatar
2010 C63
There was a recent DIY brake thread, search and ye shall find. The sensors are extremely easy to swap out - as are the pads. I just did all four corners with R4S's and it was surprisingly easy.
Old Feb 17, 2015 | 04:09 PM
AMGPower88's Avatar
C63 AMG
Wait so there are sensors we need to change ??
Old Feb 17, 2015 | 04:37 PM
Clark Kent's Avatar
2010 C63
Yes, on the passenger side (both f & r). I'll see if I can post some pics. But, simple needle nose pliers and a gentle tug will detach them from the pad area. And a 8 mm socket to detach from the caliper. Get in there and look around. This is easy!
Old Feb 17, 2015 | 05:27 PM
AMGPower88's Avatar
C63 AMG
Nevermind, just supposed to swap them out and put them on the new pads.
Old Feb 17, 2015 | 05:38 PM
Clark Kent's Avatar
2010 C63
Yes, buy the sensors. They are super easy to replace.
See the wire?
Old Feb 17, 2015 | 05:40 PM
Clark Kent's Avatar
2010 C63
Use needle nose pliers to gently pull the connector straight out.
Old Feb 17, 2015 | 06:04 PM
Clark Kent's Avatar
2010 C63
Then use a 8 mm socket to detach from the caliper so you can get it out of the way.
Clark Kent's Avatar
2010 C63
Old Feb 17, 2015 | 06:09 PM
Clark Kent's Avatar
2010 C63
Use a hole punch on the outside of the pins and needle nose vise grips on the inside.
Old Feb 17, 2015 | 06:11 PM
Clark Kent's Avatar
2010 C63
Might as well use the old pads to depress the pistons.
Old Feb 17, 2015 | 07:43 PM
Clark Kent's Avatar
2010 C63
Take the old pads out.
Old Feb 17, 2015 | 07:45 PM
Clark Kent's Avatar
2010 C63
Reassembled
Old Feb 17, 2015 | 07:46 PM
Clark Kent's Avatar
2010 C63
Reassembled
