C63 AMG (W204) 2008 - 2015
Verde Axis V99
Old Feb 3, 2015 | 09:01 AM
AMGangster's Avatar
2010 C63
Verde Axis V99
Just a warning to those who are looking at this wheel. The factory TPMS will not work on the front of our cars as they hit the calipers. The valve stem holes are located in the middle of the width of the wheel. Therefore, you have to run flush mount valve stems and strap the tire pressure sensors to the barrel. I ended up doing it to the front and rear to keep them matching.
Other than that the wheel is decent enough quality and is relatively lightweight. I can't wait for our 15" of snow to melt off!
Old Feb 21, 2015 | 11:55 AM
Killervette's Avatar
2012 C63 AMG
Thanks for the tip!
Old Feb 21, 2015 | 01:39 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
Pics?
Old Mar 25, 2015 | 05:54 PM
Already's Avatar
E55/335i
Originally Posted by VaclavSV
Pics?
+1
Old Mar 26, 2015 | 01:02 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
That is the case with many aftermarket three-piece wheels that have a "clean" front where the bolts are reverse-mounted (my HREs and DPEs included). The fix is usually to put a SECOND valve stem hole on the angled part close to the inside lip on the inner barrel where you put the TPMS sensor, and use short Gorilla valve stems & caps on the hole in the center.
Old Mar 26, 2015 | 01:44 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The "fix", in this case at least, is just not to get them in the first place. It's a very common pattern, and I bet you can find 10 wheels that are visually almost indistinguishable, that will fit properly. Drilling another hole and plugging the center one... uhhhhh notsomuch. Would probably do that for HRE's, but not for $250 rims.
Old Mar 26, 2015 | 01:49 PM
Diabolis's Avatar
Sorry - didn't mean that THE END USER should drill the other hole. You just order them that way from HRE or DPE. Have no idea what the Verdes are - if they are cheap wheels, the fix is indeed not to get them in the first place. My bad.
Old Mar 26, 2015 | 02:05 PM
JeffDL's Avatar
C63
someone used to make like a butterfly clip that would attach to the center mount valve stem so you could then attach the TMPS to that. I did this with the forgelines on my 335
something like this:
