C63 AMG (W204) 2008 - 2015
Need Tire Size Help On 2013 C63 Sedan
Old Feb 3, 2015 | 08:12 PM
C300v8's Avatar
2012 c63
i current run 235/40/18F 255/35/18R (Stock )
think about to upgrade PSS 245/40/18F and 265/35/18R will i have any rubbing problem?
Old Feb 3, 2015 | 08:43 PM
solekeeper's Avatar
A V8
+1 i want to know if i can run 265's in the rear as well
Old Feb 3, 2015 | 08:46 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Nope. No rubbing. If you are not dropped at all, you can even run 275 rears
Old Feb 3, 2015 | 08:55 PM
solekeeper's Avatar
A V8
sweet.. that should allow some more mileage out of the tires.
if i run 275's will it be perfectly flush with the quarters? would you happen to have pics?
Old Feb 3, 2015 | 09:20 PM
C300v8's Avatar
2012 c63
thanks how about the front
any rubbing issue with turning?
Old Feb 3, 2015 | 10:49 PM
I am Jeff's Avatar
There's a good picture in that thread of a 275 pss.
https://mbworld.org/forums/c63-amg-w...ch-wheels.html
Old Feb 4, 2015 | 02:27 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Although you may be able to mount them, 275s are just too wide for the 9" rear rims to provide any benefit over 265s, plus they will look funny. Stick with 265s on the rear unless you also have wider rims.
Old Feb 4, 2015 | 02:43 PM
C300v8's Avatar
2012 c63
ok thanks Diabolis
i will stay with 245F and 265R with PSS
Old Feb 7, 2015 | 06:49 PM
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
my car is dropped, im looking to go a little wider on the rears, will 275s rub or will it be really close? Dont really drive the car much either and there are almost no potholes in orlando to be worried about bumps. Main concern is grip & performance, not looks.
I also need new front tires, what size would you guys recommned for the fronts? I am going with the michelin pss
