C63 AMG (W204) 2008 - 2015
Flapping noise 25-30mph... baseball card in spokes?
Old Feb 12, 2016 | 12:50 PM
HBC350's Avatar
'18 C63A Cabriolet
Bump. Mine is back to the baseball card in the spokes at 25-35mph under light throttle or coast. Going in next week for B1 so I'll mention this as well and see if we can get resolved. It happens every time so at least I won't have to endure the "unable to duplicate customer concern!"
Old Jun 7, 2016 | 07:19 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Mine had this noise in a pkg garage turning right..... dealer replaced the front left wheel bearing under warranty. Noise gone. Bad wheel bearing @ 10K miles. FYI.
Old Jul 5, 2016 | 04:58 PM
rohitC63's Avatar
C63 AMG
Don't wanna revive an old thread but it's better than creating a new one.. Drove around for 10 minutes with no flapping noise but as soon as I put my foot down, the noise started. I don't an LSD so that shouldn't be a problem.. It's coming from right under the passenger seat and I looked under the car and see nothing
Old Jul 5, 2016 | 08:26 PM
AA717driver's Avatar
‘04 996 C4S, ‘18 GLC, ‘19 Alltrack
Originally Posted by rentzington
Have you checked for a baseball card in your spokes?
Sorry had to
That would take a hell of a clothes pin!
TC
Old Jul 5, 2016 | 09:56 PM
compaddict's Avatar
2016 S63, 2013 SL63
My car did that! One day it stopped and I noticed the "shark fin" fell off.
Old Jul 5, 2016 | 10:03 PM
rohitC63's Avatar
C63 AMG
So I figured out the problem on mine... My front tire thread string came off and was hitting.. Got new tires now
Old Jul 6, 2016 | 10:22 AM
  #32
Elahe.z1989's Avatar
bike
deleted
Old Dec 19, 2016 | 02:23 PM
  #33
HBC350's Avatar
'18 C63A Cabriolet
My 2014 507 Coupe was making a loud ratcheting noise from the right front wheel area when turning full lock to the left at slow speeds. Also sounds like bad wheel bearing. At the dealer now so we'll see what they come up with.
Old Sep 7, 2021 | 04:22 AM
  #34
PARADOX_sf's Avatar
CLS 55 AMG P30, C32 AMG
I am having the same problem on W219 with P30 LSD option. Any idea is this normal or what is wrong?
Old Sep 8, 2021 | 12:51 AM
  #35
swedepat's Avatar
2011 C63 AMG, 589hp
My car had a strange flapping noise in those speeds also.
I found it to be one of the undercarriage plastics had became loose at the rear(behind fueltank)
Wind made it flap.
Old Sep 9, 2021 | 04:33 AM
  #36
PARADOX_sf's Avatar
I've found the problem. When the differential is fitted with lsd, the lsd unit creates a lot of metallic particle which circulates through the oil. The differential was not fitted with magnet plugs and all of these metallic particles damaged all of the bearings. It is extremely important to change the diff oil regularly then it has lsd unit installed. On my unit the oil never has been changed. All the bearings are bad. I may post some photos later. The lsd unit is worn out too. It need a rebuild. The unit has more clutches and plates compared to bmw 188 and 210. The clutches and plate are the same as ZF 188 lsd unit. The ramps are 50/90 deg with 50nm static load. I believe the unit is 40% lock up.
Old Sep 16, 2021 | 04:08 PM
  #37
PARADOX_sf's Avatar
https://mbworld.org/forums/c63-amg-w...ial-noise.html
photos here!
Old Nov 21, 2023 | 01:07 PM
  #38
PARADOX_sf's Avatar
I hope this would help:
