Gas mileage?
I get about 7-10mpg in the city. Around 14mpg with some highway thrown in & about 19mpg all hwy
I actually expected worse with my car, my grocery getter is an Acura TL and during the first week of owning my c63 (commuting as well as playing around with it) and I'm only finding the c63 to be about 20-25% worse on fuel. I also notice that I'm putting way more mileage on this car because its fun, so I'm burning through it fast.
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I get the same mileage as you.
50/50 highway/city. Filled up yesterday 60L for 445 km.
No complaints here. Highway driving yields better numbers.
Better gas mileage than I expected, worse than my Jeep.
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
The biggest culprit to poor mileage is not how you drive - it's traffic.
Stop and go traffic you're looking at 20-21 L/100km, driving in C no faster than the limit.
In Toronto, even if I floor it whenever I can when there's no traffic, I still get under 20 L/100km consumption.
Stop and go and short distances are the biggest fuel consumption variables living in a big city.
On the highway at 85 mph (actual, meaning speedo shows about 88 mph), I get 10.5 L/100km in the summer, no AC. I think that's around 20 mpg.
I have the 507, but not sure that makes that much of a difference in city driving.
#32
#33
Wanted to add that my C63 is still new (3000 miles), so the mileage will undoubtedly improve.
ShaneN. I think you have the W205 C63, as you refer to a heads up display... so you should get better mileage that the W204.
That said, I was getting around 17-18 L/100km during break-in, taking it very easily and not driving in rush hour traffic.
I think the computer is pretty accurate - off by 2-5% if I compare to the gas pump and the odometer.
#34
2008 E320 Bluetec, 2008 Lexus RX400h, 2012 Honda NC700SA, 2005 Acura MDX, 2000 Mercedes ML320
I get 32-35 mpg hwy depending on the tires. A full tank easily gets me from Rochester, MN to Rochester, MI. Interestingly I get better fuel economy with Michelin X-ice compared to all-season Goodyear tires. This may partially be due to the Goodyears being older and close to being worn out.
#36
I can get 25mpg at best and usually around 15. Interestingly I am working with Jerry from Eurocharged on an Economy Tune. Still with all the wide open power but leaner closed loop running. These engines are run overly rich for warranty reasons due to the timing they run. I have heard that from a couple of sources now.
1850RPM low load we see lambda 1.09 stock 1.13 with preliminary eco tune and 1.02 with the standard V5 EC. Looking to progress this over the next month or so once we have the required data logging and knock detection in place.
My driving is very much like the Rally cars, moments of silyness and the creeping to the next fuel station. These guys also run very lean on light load cruise due to how important fuel consumption is for them.
If the C had the same size tank as the E I doubt we would be having this conversation. But back road fun to remote and pretty places requires RANGE!
#39
I have to say this is the hardest car I have owned to drive like a Nana between 'stages' they just sound and feel sooo good.
That said, purely from an engineering perspective, I don't think there is an excuse for any intelligently built, variable valve timing, adaptive mapped, aerodynamic vehicle regardless of capacity or cylinder count not to do at least 40mpg light load, closed loop...
#40
#41
I have seen 8.9-9.1L /100 Kms before long highway cruise control set no breaking coasting down hills and a little extra psi in the tires...
#42
There's lots of great data on Fuelly. Here's mine: http://www.fuelly.com/car/mercedes-b...utertom/345599
That's every fill up since I picked up this gas guzzling nonsensical car.
Never had more fun in a car too. I think the two might be connected...
#43
#44
Not true at all! There are loads of race formulas where fuel usage is key. F1, Le Mans WRC. Efficiency in all its form is key for any competitive sport... FYI, a Mercedes C63 is NOT a race car. It is a fast and in my opinion wonderfully silly road car. Tweaking some more efficiency out of it especially if you can keep all your top end is a win win and I think how any electronically mapped engine should be set up.
#45
I've had experience with this Throttle Controller by Pivot. We used it in our 135i demo car back in the day with great results. Makes a huge difference in (Eco mode) MPG/Throttle response. It works by controlling the throttle plate, 3 modes - 12 steps of acceleration.
I believe there is a MB universal specific harness:
DP-Pivot-TC+15A-MB-AClass
http://www.pivotracing.com/product/THF
#46
I'm averaging about 15MPG.
But, I sit through a lot of traffic. It's more like 50% Highway / 50% City, but my City is a lot of stop and go. Not too bad I would think.
I've seen as high as 17MPG, and as low as 13MPG. These are all real-world numbers calculated from the Pump, not on the MFD.
#47
I am sure you guys have seen this but see Steve Dinan's comments on transition tuning for efficiency on race cars. What I have been bashing on about for a while but good to see it reinforced. Also NA cars can see power gains from ECU tunes when the manufactures deliberately detune for marketing. Hence the reason I personally went for the base model C63 because I know that will give the best gains.
#49
how many of you drive in manual mode?
i struggle to get 150 out of a tank. but always in manual mode.
i should try driving in C for an entire tank. but this will probably never happen
#50
I honestly haven't found any appreciable difference in MPG between C, S, and M. I get as low as 8 MPG in stop and go traffic, and have seen mid-20's for freeway cruising.
