keyless-go question
'12 C63 Black Series, '12 ML350 BlueTech
I have "keyless go" as an option on my build sheet, and my doors do unlock when I touch the handle. However, pressing the button manually with my pinky does nothing. Am I missing something? I thought I'd give it a try before buying the real start button.
#33
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I'm confused, it sounds like u don't have a "real" start button yet but try to push start ur car? The actual start button has a chip behind it that detects ur key.
#34
So I think I am in the same boat as you Purpleheart, my build sheat says "keyless-go" but I still have to put my key in and turn it. However, I do not have to hit a button to unlock my doors. Let me know what your outcome is because I would MUCH prefer the push button start to actually turning the freaking key, so much effort.
#36
C63 507 with BS Body; 2008 SLK 55
Mike,
this would be really strange. The button definitely has no chip, so it istelf does not need coding. And keyless go requires hardware, e.g. antennae and receivers to communicate with the key, so it is not just a software matter.
Could it be, that:
1. Your car is originally a keyless go car, but
2. a previous tune disabled the start function in the ECU, and
3. now OE says it can be re-enabled?
That would be unusual, though.
Could it be, that:
#39
Update:
First things first, huge shout out to Andrew, (AMG893), for hooking me up with a button. Came from Australia to NY in like 3 days. Thanks again buddy.
For everyone else, especially if you bought used and didn't have the push button, I recommend you get your build sheet printed up and see if keyless-go was an option. ****All you need is the button, no coding whatsoever*** As far as how long it takes to mod you car, how about 1-Mississippi. Just put the button in the slot and done.
Lastly, I used to be like "big deal, so turn the key." Well, I have to admit, this is amazing. Not even having to dig into pockets and fumble around with keys is a very nice touch. Just get it, push, and go.
AGAIN *****NO CODING REQUIRED***** (I stress this because I know it has been mentioned here).
Thanks again, Andrew.
#42
Do you need to print a build sheet? I thought all keyless-go optioned cars have the touch handle lock/unlock thing? If you have that, then you can throw in the button.
#43
#44
Update:
once you go keyless you never go back, it's a must have for me now
#45
Yeah, that'll work as well. I was just too dumb to realize this (and didn't have keyless in my previous c63) so one day I was getting the build sheet from the dealer to confirm I had an OEM LSD and saw keyless on it.
#48
Not sure about US.
