Mods for better times/hp
Magnuson-Moss Warranty Act (U.S. federal statute; 15 U.S.C. § 2301 et seq.).
Aftermarket modifications that improve performance do not automatically void a vehicle manufacturer's original warranty, unless the warranty clearly states the addition of aftermarket equipment automatically voids the vehicle's warranty. Short of that, the manufacturer must prove that the aftermarket modification/equipment is the direct cause of the component failure.
I am all for make your car your OWN, play with it, work on it, drive the **** out of it and enjoy it.....but as for Mag-Moss, it is not hard at all for any mfg to get around that when it comes to changing the OEM operating parameters of a computer controlled engine....they set it up to run at X efficiency on Y program...when Y program is changed then X efficiency is gone, and it is NOT the mfg who threw X out the window..... Just saying, you may be covered, may not be covered...know your financial limits and make your own decision
I was just throwing that out there. It really depends on the fact pattern. If someone installs an aggressive aftermarket tune on a turbocharged car and the wastegates end up crapping out, the manufacturer is likely going to have some strong arguments re: whether the tune played a direct role in the failure.
When I was in the BMW community, I always went with Dinan or BMW M Performance modifications. Both lines of products offered very attractive warranty coverage.
One of my highly tuned E90 335i sedans (N54 motor) had a Dinan high-capacity oil cooler. The cooler developed a hairline crack and Dinan sent me an entire replacement kit (brand new) next-day air. Dinan paid my local authorized BMW dealer for the 10+ hours of labor required for the removal/re-installation. Zero fuss and no finger pointing.
On a side note, it looks like Eurocharged offers a limited/conditional warranty on its tunes:
http://www.eurocharged.com/warranty
However, there seems to be a difference between optimizing a tune to reach the vehicle's maximum safe operating potential over the long-term (more than say just two to four years before flipping it for a new car) and what may be a overly aggressive tunes that may exceed what some engines may be able to handle over the long-term based on DD use. Of course if the car is a garage queen, only taken out a few times a month to track, then it likely doesn't matter how aggressive one's tune is. You're not likely to use it enough to damage anything as a result of an overly aggressive tune in the time you own it. I think that's where the conflict in the discussion is.
A tune within the parameters of what the engine and transmission can safely handle should be absolutely fine. So one shouldn't be concerned over the warranty that much as nothing likely will go wrong as a result of the tune. On the other hand, if the tune is designed to maximize power at the expense of long-term operating margins, then unfortunately yes, you may be stuck with an expensive repair bill for some part MB may link, one way or the other, to the altered ECU code. As a lot of people say on this forum, you have to pay to play. So it's up to the individual to know if the tune they want to plug in is within the design parameters of what the engine and drive train can handle safely.
Moss doesn't even apply.
http://www.speedsportlife.com/2011/0...big-of-a-deal/
In 1986, BMW's 1.5-liter inline four-cylinder turbocharged M12/13 engine powering the F1 Benetton B186 in qualifying trim could produce about 1,500 bhp - but it and the transmission would only last for one lap. The power had to be de-tuned to about 1,100 bhp for practice - when the engine and tranny would last for about 30 laps, and down to about 900 bhp in order to make the full race distance of roughly 60 laps or 300 km.
Read the article at the URL I posted above so I don't have to regurgitate everythign here.
As for the Eurocharged warranty, I would like to draw your attention to the following two lines (emphasis is mine):
- Coverage is for 2 years or 20,000 miles from the original in-service date
- Motor coverage is limited to $50,000
In other words, if you took delivery of your C63 on July 1, 2013, you babied or even stored your car for the last year and a half, and then installed the Eurocharged tune two months ago when your car only had 4,000 miles on the odometer, your warranty expired yesterday. Not even close to what Dinan is offering.
That's the way I read it. Eurocharged is a sponsor here so that's something that they can certainly clarify themselves.
If am wrong though, it would mean that they would need to warranty a 120,000 mile, 6 year old car with worn cams and what not that just had a tune put on it, for the next 2 years & 20,000 miles.. now THAT would be the best aftermnerket warranty I can think of. You buy a used car, throw on a $1K tune, and you're good for the next two years.
You are missing one very important aspect here. It's not matter of what an engine (or any other product) can handle in terms of PEAK power - it's what it can handle and for how long. In other words, you have an engine that with the OEM tune on average lasts for X operating hours (or miles). The moment you increase the power by some percantage, you decrease the operating hours (or miles) by a proportional percentage. There is no such thing as a "safe" tune or a "safe" range. More power = more stress = shorter lifespan.
To clarify, I wasn't necessarily trying to make comparisons between Dinan's warranty coverage and Eurocharged's. That's why I said that Eurocharged offered a "limited/conditional" warranty. You aptly identified and emphasized those conditions/limitations.
Still, regardless of the constraints (which are very vendor-friendly), it's nice that Eurocharged does this. Quite a few MB tuners don't.
