C63 AMG (W204) 2008 - 2015
Wheel studs conversion kit
Old Oct 14, 2015 | 06:38 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Originally Posted by Carbon Dated
Just finished installing this (these?) on all four corners. I highly recommend this kit...it is very high quality. Wheel/tire/brake changes will be a snap now.
Since this is the first time I had the wheels off (bought car in April with new tires) I cleaned the wheels, calipers and rotors up good and it was worth the extra effort. I also had to go to a truck tire shop to get the lugs broke loose after breaking a socket and an adapter...that's how tight someone had put the old lugbolts on. They had to break out the big, heavy-duty truck impact wrench on a couple bolts!
For this reason alone, I'm glad I did this conversion. Would have been a nightmare trying to change a flat on the side of the road. Also looks good, much better than the old rusty and corroded lugbolts.
Very well stated. This conversion will make wheel/tire change, and/or brake check so much easier that you will think it's fun to do it than putting them off due to the awkward work you have to deal with individual lug bolt.
No matter it's for regular maintenance, or road side emergency service this is definitely a good investment for you to consider, and RB is glad to offer the parts you need for an easy installation.
Old Nov 11, 2015 | 02:46 PM
Clark Kent's Avatar
Veteran: Marine Corps
2010 C63
Hi RB, your link on the first page isn't working for me. Would you please PM me the price of the conversion kit shipped to 78745? Thx.
Old Nov 11, 2015 | 04:41 PM
CLS550
Sorry the broken link just fixed:
http://www.racingbrake.com/Mercedes-Benz-s/7210.htm
Old Nov 25, 2015 | 09:36 PM
AMG3.2's Avatar
C63 AMG, P30
Are there different sizes of these or are they just a standard size? I'm interested in going this route over bolts but don't want the studs to stick out to far with a 12/10 mm spacer.
Old Nov 25, 2015 | 10:12 PM
Clark Kent's Avatar
2010 C63
I just installed the wheel stud conversion kit and 12/10 mm spacers last weekend. It looks great and I really like it. When I get home I'll try to post some pictures so you can see it for yourself.
I am lowered on KW V3's and 18 inch stock wheels.
Old Nov 25, 2015 | 10:52 PM
Clark Kent's Avatar
2010 C63
12 mm up front.
Old Nov 25, 2015 | 10:57 PM
  #32
Clark Kent's Avatar
2010 C63
10 mm on rears
  #33
Clark Kent's Avatar
2010 C63
Old Nov 25, 2015 | 11:00 PM
  #34
Clark Kent's Avatar
2010 C63
Old Nov 25, 2015 | 11:02 PM
  #35
Clark Kent's Avatar
2010 C63
I experimented at first and tried the 12 mm on the rear. I liked it a lot but it would rub with enough compression.
Old Nov 25, 2015 | 11:24 PM
  #36
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
The studs are long enough to enable the use of spacers up to 20-25mm thickness, depending on the rim and lug nut design. So, with a 10 mm spacer they would stick about 15 mm out of the lugnut, which is not looking bad at all.
In many rims with deep bolt holes, you would not see the studs at all.
Old Dec 1, 2015 | 07:55 PM
  #37
CLS550
There are some discussion on other source of wheel studs with price comparison.
Just to provide some background of our development for these wheel studs. We started making wheel studs for SRT4 and EVO 8/9 back in early 2000 when these two popular motorsports car had continuing broken studs issues (on tracks). Today RB wheel studs are still a popular upgrade/replacement to OE studs.
RB wheels studs are made of 1060 alloy steels, heated treated and certified to 10.9 grade to the following strength:
Proof Load: 830 Mpa (120,000 psi)
Tensile Strength: 1,040 Mpa (151,000 psi)
Studs are made with hex head for an easy installation
Installation: Torque studs to 45-55 ft-lbs
The stud length is made to 80mm, a convenient length with extra length for wheel spacer as necessary.
Wheel nuts are "Chrome Plated" for lasting surface coating w/o getting corroded.
For street use and price conscious customers, lower price source may be just fine. Just like anything else there is always a price difference among different mfg sources, but for a safety item like wheel studs it's worthwhile to find out more than just comparing the pictures and prices.
Old Dec 17, 2015 | 08:20 PM
  #38
BerBer63's Avatar
2009 C63
My normal 17mm deep socket I use on OEM lug round bolts and all others conical MB bolts didn't work with these wheel nuts. I had to used an 18mm deep socket, however it doesn't fit in the deep recess on the OEM 19's to torque down.
Is this the way they are supposed to come? Nuts seem a tad big ...
Old Dec 17, 2015 | 11:01 PM
  #39
8o8is's Avatar
'10 C63
Studs are way more conventient especially if you got different sets of wheels. I had to convert this way because the lug bolts that came with my aftermarket wheels were a smidgen too long. Lug bolts were hitting the parking brake mechanism inside the rear rotor hat. That was "NOT" a pretty sound when I first rolled out of the garage.
Old Jan 3, 2017 | 01:28 PM
  #40
AMG_55_cruiser's Avatar
2004 CL55, 2003 SL55, 2017 S63 Cabrio and 2009 G55
Happy New year Everyone. I know this is old thread but wanted to ask a few questions.
If this kit or others are still available are they offered in shorter lengths for wheels without spacers?
Also what do you do for locks when converted? Are people just using 4 of the studs and using lock as usual?
Thank you,
Mick
Old Jan 4, 2017 | 01:41 AM
  #41
CLS550
We converted our shop car CLS550 first time we did the brake kit upgrade - here is the pic.
You would never realize the convenience until you do this conversion. We just left the lock nut w/o it., and once the nuts are on you will never see the stud extended out even w/o a wheel spacer.
http://cimg0.ibsrv.net/gimg/www.mbwo...ebc7ec70c6.jpg
Old Apr 24, 2017 | 12:54 PM
  #42
Phil_T's Avatar
C63 AMG Saloon
Thank you,
Mick
This is what I still want to know, I dont know about you guys in the US but in the UK the wheels would be stolen if people knew they were no locking wheel nut. What do you do about the locker? Or what can you do if you still need the locker?
Old Apr 24, 2017 | 01:09 PM
  #43
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
They make locking open-ended lugnuts. Search Google. I know for a fact that RAD makes them in cone seat because I have them. So do McGard and many others
Old Apr 24, 2017 | 01:27 PM
  #44
AMG3.2's Avatar
C63 AMG, P30
Damn. I've never used locking nuts in the Bay Area, the South, or the Northeast. Never thought twice about it either.
Old Apr 24, 2017 | 01:57 PM
  #45
Cli63's Avatar
2012 c63
I did the conversion and use currently use 4 nuts that came along with the kit and a locking one i got from amazon.
Amazon Amazon
Old Apr 24, 2017 | 03:28 PM
  #46
BLKROKT's Avatar
For what it's worth, I use OZMO Engineering 12-point Ti lug nuts. Not many wheel thieves carry around 12-point sockets. But if you have someone casing your wheels, not much is going to stop them if they prepare, including locks.
Old Apr 24, 2017 | 03:34 PM
  #47
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
JBWeld the nuts on. That'll stop em!
Old Apr 24, 2017 | 04:44 PM
  #48
Mort's Avatar
Ya, that oughta work.
Old Apr 24, 2017 | 04:50 PM
  #49
BLKROKT's Avatar
JBWeld YOUR own nuts
Old Apr 24, 2017 | 04:52 PM
  #50
AMG3.2's Avatar
C63 AMG, P30
Why would you JBWeld, when you can weld?
