C63 AMG (W204) 2008 - 2015
More parts needed with lowering springs?
Old Oct 25, 2015 | 12:57 AM
1AMG2NV's Avatar
2014 Jeep SRT
Hey guys, buying a 2014 C63 soon and planning on lowering as soon as I get it. I'll use H&R springs (unless there are better springs to use) and wanted to know if more suspension parts are needed to get a good alignment?
do I need to purchase aftermarket control arms or anything else? Or am I good to go, just installing the springs and getting alignment?
I'll be rolling on the stock wheels and tires for a while
Thank you for any input
Old Oct 25, 2015 | 01:19 AM
iShootYou's Avatar
2019 e63S, 2017 Audi R8 Twin Turbo
I purchased 17mm spring pad in the rear from Mercedes to raise the back up a little. The pad makes the rear sit right above the tire.
spring pads part number A 210 325 04 84
Old Oct 25, 2015 | 01:58 AM
1AMG2NV's Avatar
2014 Jeep SRT
This combined with H&R springs? Does it rub or something w/out the pads?
Old Oct 25, 2015 | 08:55 AM
iShootYou's Avatar
I don't think they will rub, I personally just like the way it looks and the pads are not expensive
Old Oct 25, 2015 | 12:40 PM
CarHopper's Avatar
E63S | X5
As long as you're running an OEM wheel/tire setup, you'll be fine.
If you have aftermarket wheels or tires that are wider than 265 then you'll have a chance to rub. But we'd need to know more about your setup in order to tell.
The pads in the rear are a nice touch because it gives the car a more aggressive nose down look rather than risking the nose up look that makes it look like you've got bodies in the trunk.
Old Oct 25, 2015 | 04:22 PM
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
Only thing I have heard about H&R springs only setup is the fact that it can cause the car to pull right all the time. Its the one thing that has stopped me from purchasing them. I had H&R on my S4 and never had issues.
Old Oct 25, 2015 | 09:04 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
It's not the H&R springs but the alignment. Most techs follow the alignment specs blindly and get it within OEM spec only. Alignments can be a dark art and a knowledgeable specialist will be able to get it right.
Old Oct 25, 2015 | 11:48 PM
1AMG2NV's Avatar
2014 Jeep SRT
Just planning on lowering on stock rims and tires. May do rims and tires much later. Sounds like springs and pads are what I need!
Thank you!
Old Oct 25, 2015 | 11:49 PM
1AMG2NV's Avatar
2014 Jeep SRT
Thanks guys for the additional info!
Old Oct 25, 2015 | 11:56 PM
C63vil's Avatar
'12 C63 AMG P31
Lowerig a car you might have to start dealing with purchasing tires more often, specially rear tires.
I keep my C63 with stock springs , I love the hight , and I love not to deal with aligment or worn-out issues.
Old Oct 26, 2015 | 12:15 AM
1AMG2NV's Avatar
2014 Jeep SRT
True, it does look good stock...ill think about it more then. My friend keept stock hight but changed wheels and tires to fill the gap, looks pretty good
Old Oct 26, 2015 | 12:28 AM
C63vil's Avatar
'12 C63 AMG P31
Lowering a C63 it is more aggressive look, is my personal opinion, the stock suspension is just great. if I were you, I will put spacers to fill the gap a little bit.
Like I said, to me the suspension is awesome. BTW my car is my dayli driven, I don't track my car much often.
Old Oct 26, 2015 | 10:30 PM
1AMG2NV's Avatar
2014 Jeep SRT
Sent u a PM
