Weistec Stage III SC. Stock Engine Internals goes 10.22.
This is a Weistec tune, but Allen @ International Autohaus who built it, spent quite a bit of time on the dyno, and with the help of Weistec they got the tune to where they want it.
It is not pumped up, it is just perfected. Rather than using a base tune, Allen spent time of the dyno getting all the variables right.
I think the headers also made a big difference. I was running a full iPE system and changed the headers to a set of his custom built headers. The iPE was restrictive and this showed with a significant wheel hp gain with the same setup but different headers.
#33
It might be the headers, it might be the V2 of the tranny, it might be a well prepped track on a perfect night for racing, but the car is the same Stage 3 kit, belt and 67mm pulley that everyone else has. Only thing different is the the tune and headers.
If you look at the time slips the 3 runs were all done in 20 minutes (6.51pm, 7.02pm, 7.13pm). The car didn't have time to cool and still ran consistently.
#36
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
It's a little easier for me to visualize on a spreadsheet. Comparing your three best times on the board - Merc63, Mr747, and charliekay - you can see the differences immediately.
![Weistec Stage III SC. Stock Engine Internals goes 10.22.-fastest-20sc_1.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/371674d1542319896t-weistec-stage-iii-sc-stock-engine-internals-goes-10-22-fastest-20sc_1.jpg)
Whatever you're doing charlie, it's working man. Your car seems to just make a lot more power at a given SC stage, evidenced by how fast you were running at Stage 2.
#37
My runs were done at about 2500-3000 dA range, far from sea level. But your making another 100hp than I am, so it's not the tranny or the prep. The car is running strong. I suspect they are running more timing in the tune perhaps. Lots of guys are running the mbh headers and aren't putting down that much power. That mph is huge.
#38
Former Vendor of MBWorld
Our latest transmission upgrades do help getting the car down the track much faster. Hope this helps guys.
Weistec Engineering
#41
It is not just my car, Weistec is getting faster.
The tune is our out of the box Stage 3 tune. The issue was the long tube headers, and partly the intake system on the car. This car actually dyno'd low on the dyno International Autohaus was using.
Weistec Engineering
Weistec Engineering
Thanks for your help with the car, looking forward to going faster.
#44
Jerry from Eurocharged told me in an E mail that MBH headers make less power then the design used by ARH. If this is true or not I do not know. I do know that my car seems to be down on power compared to your average 63. It seems quite a few 63 people run MBH's tri-y set up and make power with the e.t. and mph to back it up. You car is hauling absolute *** though. Good job!
#45
That's the first time I've heard that one. I thought it was pretty accepted that the MBH setup makes the most power out of what's available off-the-shelf.
#46
I was sceptical about the difference the headers would make, but i trust my guy and he was adamant the existing headers were holding back power. I decided to try it, and how right he was.
#47
There are a few threads from Mike at MBH where he goes really in depth as to why they went with the Tri Y design and the experience they have making headers. That was the reason I went with them, but my car had power issues so I wanted Jerry to look at the tune. He responded with an e mail stating that cars with MBH long tubes make less power, and left it at that. I was a little surprised to hear it, but it seems to not be exactly true from the research I have done.
#48
well the mbh headers were also probably designed with the thoughts of an N/A motor. At the time they were produced i dont think any blower cars were out there yet. The scavenging affects of a properly designed header for an N/A car arent going to have any benefits to a blown car, Im assuming this probably becomes a restriction eventually since the air flow volume changes so drastically with the blower setup.
#50
I'm not Shure but if PP Performance car, mr747, CharlieKay and myself as many other Weistec cars are using MBH tri Y headers and are running fast I think something has to be right with this headers.
