Magnuson "Hammers" the AMG C63
https://dl.dropboxusercontent.com/u/...nrc_asm.55.avi
And some images.
And some images.
When are you going to do some testing at the track??
And some images.
no torque numbers for the superchargers to post yet?
However, we have a couple of the early-release kits intended for customers that regularly run 1/4 miles.
We have done testing on circuit tracks - that's the track medium that we find best verifies durability & sustained load.
We will ... These units have been run on several independent dynos on two continents and we want to aggregate them & show multiple vehicle results. More data available shortly.
Available in limited numbers during December.
H
The 20C temp with 2.24 correction factor seems odd. I am not sure I understand how that works. Right around 75 degrees F correction is zero. Colder temps get .xx and warmer gets x.xx correction factors.
If it delivers 500-525 WHP with stock exhaust in SMOG legal configuration on OE Tuning's dyno with Jeremy's stamp of validation I'll be all over it.
"We have not run quarter-miles ...we all know that impressive 1/4m's is as much about the car setup/tyres/day as the power/torque delivery."
Anyone doing a blower needs headers without a doubt.
People need to be real clear on this when talking dyno numbers. There is also a correction factor people use on a Dyno Dynamics that is NOT constant from shop to shop. I'm actually surprised no one has bought it yet. I know some of you guys have big bucks.
A C63 tire and suspension setup is going to be pretty generic. Your either on drag radials or not. DA of the track would be the difference maker.
