KRIS' BUILD THREAD V2.5
Thank you guys,
For the members who inquired about the face lift tail lights. I have had them for 8 Months now and no issues (so-far). The tail lights are working as they should. The set comes with a pair of resistor boxes that you plug in-line to your factory harness. It requires 0 modifications and does not trigger any lights on your dash.
Its a good option for those who have a 2010/2011 PFL W204 who cannot simply code there existing Sam unit.
#32
Thank you so much my friend
Straight bolt on, no retune necessary. The Factory ECU adjusts accordingly.
#35
You have to get it coded to your car to transfer over your service history and ODO reading. Once its coded to your vehicle, its plug and play.
Learn from the best
