Low coolant warning on 2012, should I worry?
I read in the past that this was a sign of head gasket failure on the first models.
The car is still under warranty for a short while (I'm at 91,000km). Could this be just a normal thing for this mileage or should I start looking deeper into this?
Take a look around the engine bay and if you don't see any leaks top it off and keep driving. If the message comes quickly take it in or consider taking it anyway right before your warranty expires just to be safe.
I will top it off and monitor carefully. Hopefully it's just normal stuff.
Any coolant should do correct? Just want to make sure MB doesn't have a certain affiliation with a specific coolant type.
Contact your dealer and if you are on good terms they may top it off for you.
