C63 AMG (W204) 2008 - 2015
AMG3.2's Mod Journal
Old Oct 10, 2017 | 09:20 AM
  #276
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I wish they'd change the default on quotes with images to change the img tags to url so we don't see the same images embedded over and over.
Old Oct 12, 2017 | 12:15 PM
  #277
AMG3.2's Avatar
C63 AMG, P30
I know right?
To answer the other question -- just some Duplicolor Silver I have laying around the garage.
Old Nov 1, 2017 | 12:18 PM
  #278
AMG3.2's Avatar
C63 AMG, P30
Been tackling a new front end "look" the past few days. Ordered Eagle Eyes FL style PFL headlights and retrofitted them with Morimoto EvoX-R 2.0 D1S Projectors. Some pics below of the progress. Given that these lights were made for a Halogen car. They need to be completely re-wired for a Bi-Xenon car. It's not that bad, but I'd had a TON of help from a member here, jptaylor.
Attachment 441629
Removed my front bumper to have as much working area as possible:
Baked the headlights open. 200F at 10 mins does the trick.
Attachment 441632
Removed old projector and started to clean up the wiring. The blue and red wires below are the positives for the LED's. The grey is the ground for the turn signal as well as the LED's. The green wire is the positive for the turn signal.
After that, it's quite easy to start testing with a 9V battery to make sure everything is working.
Attachment 441634
Time to start wiring the high beams and low beams.
High beams just ground to any wire and the positive is the other wire coming off of the projector solenoid. Either way can be positive or negative. This is wired to the high beam signal on the factory harness.
Next is time to remove the factory ballast plug.
Baked open my factory headlights to remove this plug.
All you really need is the 3 large wires.
They correspond to the following note cards. On plug #3, disregard the "black and green" note. Those wire to pin #2 on the factory harness.
Doing some testing to make sure my wiring was done correctly.
Final testing before baking the headlight back together.
If this is the first time you're doing this and are very diligent throughout the process, expect this to take you roughly 20 hours.
Old Nov 1, 2017 | 12:25 PM
  #279
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
does the W204 have auto leveling motors?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 1, 2017 | 01:33 PM
  #280
AMG3.2's Avatar
C63 AMG, P30
Yes, I believe so. Gave those up with this mod, but I'm totally cool with that.
Old Nov 1, 2017 | 08:33 PM
  #281
Code1ne's Avatar
2009 C63
Wow man that's a big wiring job, looks killer!
Old Nov 2, 2017 | 01:56 AM
  #282
AMG3.2's Avatar
C63 AMG, P30
Thank you!
Finally finished up. Now comes the adjusting of the headlight fitment and cutoff.
Some crappy pics I shot before calling it a night.
AMG3.2's Mod Journal-d9qucof.jpgAMG3.2's Mod Journal-fonmaop.jpgAlso, installed Michelin's new Pilot Sport 4S in 235/35/19 to replace the Hankook RS3's which I do not recommend.
Old Nov 4, 2017 | 11:00 AM
  #283
MTV10's Avatar
E55 AMG & C63 AMG
Would have personally stuck with the OEM front end.... This looks 'cheap' IMO.
Old Nov 4, 2017 | 01:58 PM
  #284
AMG3.2's Avatar
C63 AMG, P30
Really? I think they give the front end a nice update. The PFL front end was starting to look a bit dated to me, but to each their own of course.
Old Nov 4, 2017 | 02:07 PM
  #285
MTV10's Avatar
E55 AMG & C63 AMG
Yeah man, to each their own. I found your car perfect before these headlights.
Old Nov 4, 2017 | 02:59 PM
  #286
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Think it looks great. Really updates the look.
Old Nov 5, 2017 | 02:25 AM
  #287
AMG3.2's Avatar
C63 AMG, P30
Thanks man. Some love it, some hate it, but I sure love it.
Speaking of lights -- if you want to send me some pics of your Depo lights, I can try to help out with your wiring.
Old May 30, 2018 | 12:36 AM
  #288
AMG3.2's Avatar
C63 AMG, P30
A few small updates just for the sake of updating the thread.
Installed Fatcat Motorsports Hard bump stops. This allows me to run a softer damper and spring rate for the first inch or so of travel (think cobblestones) and after that, a hard bump stop to limit highway speed type suspension compression.
Had my rear fenders and side skirts repainted and fitted with XPEL PPF 30 days later to prevent rock chips. (They were constantly pelted prior)
The dirt here is not under the PPF - only on the edge after driving home.
Old May 30, 2018 | 05:40 AM
  #289
SuckaGDog's Avatar
C63 AMG Black Series
PPF looks good. When you mentioned your side skirts were getting dinged up as well, was it just that small portion that protrudes out near the rear tires? Or the whole side skirt?
Old May 30, 2018 | 02:38 PM
  #290
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Really like those headlights, good job.
Old May 31, 2018 | 12:29 AM
  #291
AMG3.2's Avatar
C63 AMG, P30
Thanks. Just the wide-body extensions in particular.
Thanks. Most folks seem to dig 'em.
Old Jun 22, 2018 | 05:22 AM
  #292
SJc63's Avatar
09 c63 amg
damn this build thread is epic! love everything you've done man! is that rear flare custom?
Old Jun 22, 2018 | 09:05 AM
  #293
AMG3.2's Avatar
C63 AMG, P30
Thanks. They're not custom, per se. They're HMS fenders. https://mbworld.org/forums/c63-amg-w...group-buy.html
Old Jun 29, 2018 | 01:12 PM
  #294
AMG3.2's Avatar
C63 AMG, P30
I've been thinking about 507 stripes lately. Yes, yes, yes, I do not have a 507. But below is a scrappy mock up of what it's gonna look like. I went with grey to keep it a bit more subtle as opposed to black. I might not like them once I apply the vinyl to the car, but let's see.
Old Jun 29, 2018 | 01:23 PM
  #295
BLKROKT's Avatar
IMO if you’re going to do it, keep it black or not at all. Too many colors looks busy and mismatched. Stick with a theme.
Old Jun 29, 2018 | 01:32 PM
  #296
AMG3.2's Avatar
C63 AMG, P30
Thanks. I'll debate it. I've been slightly torn between the two. I like that the grey will match the wheels and flow nicely, while the black may flow well with the black badges, and carbon stuff.
Old Jun 29, 2018 | 01:52 PM
  #297
Crya's Avatar
2009 C63 P30
Agreed. Black nor nada. If you want to be different, maaaaaybe CF-look vinyl. But I'd want to see it "live" on the car.
Old Jun 29, 2018 | 01:57 PM
  #298
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by AMG3.2
I haven't asked yet. Trying to do some due diligence prior to giving them the go-ahead. I'm really close to selling this car now. Just don't have the will to be dealing with things like this.
You can't be that close to selling if you're thinking about stuff to add to it...
Old Jun 29, 2018 | 02:07 PM
  #299
AMG3.2's Avatar
C63 AMG, P30
Alright, let's go with black then.
Every time I realize how much effort (also money) I've put into the car, I realize that selling it would just be dumb. Realistically, I'd get someone coming from craiglist asking to buy it for "$27k because that's what the other PFL cars are going for". And the what, I'd turn around and buy another money pit (E90 M3). Not the best of ideas at the end of the day.
Old Jun 29, 2018 | 02:29 PM
  #300
BLKROKT's Avatar
Atta boy. Giving up is for losers. Double down, supercharge it!
