Dipstick - what to believe?
Which one do I believe?
And if you've got a good answer, can you explain why?
Follow the guidelines in the MB owners manual.
To me it sounds like yours is a bit low.
Oil should be checked at 80 degrees centigrade for the true reading....and you should decide on a top up of oil based off that
If you're on the high side of oil in the sump, your idle becomes a bit rubbish
Any truth in either of those statements?
