Eurocharged C63 Tune and More!
I run EC's tune, I am a huge fan of the company, have been since my old W211 days. Jerry in particular has a great rep. But that doesn't mean I am going to become a fanboi and not support legitimate questions when they are raised by the paying public.
My close friend has 2 dyno jets in his main shop and another Dynojet at his other shop and I've tested my cars on all 3 of his dynos dynoing them myself and all 3 dynos put out within 2whp of each other
I have a 13 p31 car that is the same car as they advertised getting 423+ rwt and 431rwhp. My car did 359 rwt and 400rwhp with row airboxes and other wise bone stock.how the hell are they getting 65 more rear wheel torque ?
I asked what gear and the full details of the run like I posted on my dyno.I have nothing to hide and all my info is at the bottom of my dyno sheet.run conditions,af,baro,humidity etc.
Of course they will say every dyno reads different but my numbers are UNCORRECTED and no bs
I have a very hard time believing I will get the torque and whp with there tune on my car that will be run on the exact same dyno
Also, I know you have a p31, but I believe it was a 507 on the dyno which will have a bit more from factory. I understand your argument, and that 60+ is a lot, so I'll call.
I think that is a super cherry picked dyno sheet and not a single c63 will get those numbers with stock filters and stock airboxes with just a tune.
The 507 also is rated 8 ftbs more than a p31 not 80 more ftlbs this "stock" 507 is making 65rwt more than my p31 with row boxes
Tune your car. You'll feel a difference. Stop trying to be all slick and "stick it to the man" so to say. You aren't getting a free tune if you don't make the claimed power because there are a million and one variables that play into it.
I have said this time and time again here. You want the most for your money? Take it to a reputable tuning shop and get your car tuned on a dyno. These v5 maps do make a difference, but they aren't going to get the most out of your car. They are, after all, off the shelf maps that are designed to be somewhat conservative. It's like generic drugs vs the real deal.
EC advertises numbers that are a safe average using a relatively high conversion rate for drivetrain loss when it comes to whp --> bhp for all of you-who's that are wondering about drivetrain loses.
In an effort to make some sense, and clear things up a bit, you guys are correct in the sense that the advertising claims are highly optomistic and a lot of cars may not see the claimed numbers. However, many cars will see those numbers. Here are the things that are going to effect the numbers you see:
- Altitude (Are you in the Rocky mountains? In the humidity of Florida on the ocean? In a dry sea level climate?)
- Temp (remember, if it's cold so are your tires, so your IAT's may be optimal but if your tires aren't warm even the smallest amount of slipping may skew numbers)
- The brand of dyno (heartbreak mustang? high ready dynojet?)
- The type of corrections used
- LSD? (when is the last time fluids were changed? tranny included)
- Tires (width, tread, weight)
- Wheels (width, weight)
- Health of car (are you intake filters clean?, mileage?)
- Experience of those running the dyno (strapped in right?, using the proper gear?)
- Type of gas (Quality 93? Or kwik-fil 91?)
And, for those of you wondering about this drivetrain loss, here is what I will say. Do more research, look up more dyno graphs on different c63's. You are going to find that pretty much all of them are different. Yes, when you do the calculations on the graph posted it comes out to a high loss. We are all waiting for EC to respond, however, consider things such as a lower reading car was used for the stock number and a different car was used for post tune, highly unlikely though. I'll just call this car an outlier.
Example, there is another graph out there that has the following results:
Stock: 98F, 12% humidity, SAE 1.01 = 367whp
Tune: 93F, 17% humidity, SAE 1.00 = 427whp
Roughly 14% loss here
And another (unknown temps/humidity)
Stock: 362whp / 359 wtq
Tune: 442whp / 405wtq
Roughly 18% loss here
And the EC graph w/ stock vs v3 map
Stock: 332whp
Tune: 408whp
Roughly 19% loss here
So, lets take an average of those percentages, use baseline dyno results, and claims from AMG.
Average baseline hp = 354whp
Average drivetrain loss = 17%
Factory bhp claim from Mercedes = 451
Factored in calculated loss = 374whp
AMG factory claim appears to be 20whp high in this case.
So, what does that mean? Essentially off that information Mercedes is rating the car too high from factory. Not a single one of the cars I pulled from this sample managed 374whp, and one was 42whp away, thats huge. All of the above factors play in, but still, big difference.
If you want to call a complaint department start by calling Affalterbach and see if you can get a refund on your initial c63 purchase as the advertised horsepower does not live up to what the product gave you.
However, seeing as I am annoying I'll just keep my mouth shut for you guys here on out. God forbid I give out information like how to get a MyGenius and handheld shipped to your door for $730 instead of $1200 for just the software, no MyGenius, and not to mention shipping your ECU to and from EC causing your car to be out of commission for that time. And heaven forbid I say that Mercedes and AMG were the ones who were optimistic with their HP claims rather than Eurocharged.
Sorry for the inconveniences.
It would be a bit of a trip, but Weistec is in SoCal. You also have a Eurocharged location just north of San Antonio.
Other option could be a remote tune. In basic terms, you essentially plug your car into your laptop and then the tuner will connect to your car through your laptop via their computers. Then go find a "safe" road where you can get some pulls in and they'll make their tweaks based on what your car is logging. You're essentially getting a road tune instead of a dyno tune using that method.
I've been on many forums and don't want to say whether or not that has definitely been done on a c63. I know my neighbor did this with his m3 and the results were fantastic, far better than an off the shelf map.
If someone can remote tune you (EC, Weistec, Velos, OEtuning) then that may be a good option for you.
As you can tell, many people aren't very technically/mechanically inclined so they head to the internet to search for information. Obviously, not everything you read on the internet is accurate so if I can clear things up or point people in the right direction I attempt to do so.
And yes, I was in the Marine Corps, thanks.
Lets get back to what is really important here and the drivetrain loss. For those looking for some info you can see some quick calculations in post #45 with regards to drivetrain losses and other c63's.
Otherwise, wait for EC to respond here (they're great, and they'll eventually get to this) or if you want answers sooner give them a call:
United States -- 713-462-1600
Canada -- 416-739-9997
Glad you could enjoyAs for the losses... Zcct's math has some of the examples above that 19% from EC. I don't think their claims are that unreasonable.
(zcct, I figured out how xxaarraa was calculating and used the same method. Just got 19% off the charts EC posted and used the same method each time)
Just hoping people read through thoroughly and find your post. Then they can plug in either 451, 481, 507 or whatever they "started" with and use their own dyno results to calculate what drivetrain losses they have.
Thanks buddy
That said, some of the cars out there are actually quite strong. I know it isn't a w204, but the w205's are putting down some pretty nice stock numbers. But even some w204's are proven to be quite strong and meet or exceed factory claims.
I forget the guys name (Matt Ferra? the heavy bald guy that tests a bunch of cars on youtube) used 20% drivetrain loss and took some serious flack for it in the comment sections of one of his videos. There was no response, but he may have some more knowledge on this matter than others. Even in his 850 hp weistec video I think he uses a 15% loss.
All I'm doing is telling you some possibilities into why the numbers may have come out the way they are.
Guys, if you need answers right this minute pick up the phone. The impatience here is a little... tiresome. Give it time and in the mean time read some advice from members. It may not be perfect, but it makes sense.
If I was EC I wouldn't even respond here at this point.
No one asked for lectures from you or anyone else on this thread on what a dyno is for. What you guys keep spewing over and over again is pretty straightforward stuff. Got anymore captain obvious tidbits you'd like to share? Maybe about how you think oil filters need to be 'broken in'? Geezuz.
EC made claims. Some of the assumptions behind their claims seem shaky. We are hoping they'd clarify how they got the numbers THEY ADVERTISED. This is (and should always have been) a conversation between EC and their current/potential customers who have a question on their methodology. You and purple and posse should chill out and stand in a corner and watch.
Kapish?
Secondly, it's all you guys who are failing to understand what dynos are used for. You want answers pick up the phone and call EC. It's not hard.
And third, stop PM'ing me.
are people seriously this dense that they haven't clued in that we all live in different environments? with different air/humidity/elevation and whatever else
This is a huge concern to as a potential custom and asked a few simple questions in a thread the company itself made to promote and sell there tune.
Oe Tuning put out a dyno with a stock car,p31 car 507 car and all of the with before and after gains and all cars bone stock were making 355-360 ftlbs of torque just like my car did.
Not a monster 423rwt stock! If this car has headers with no cats already I won't get near its advertised power with just there tune.
Dynojet are VERY compatible to other Dynojet my friend
My dealer in Boston is a renntech dealer and can tune my car.
They also put in a new tranny on my e55 that was renntech parts.
Right from there web page
RENNtech has been at the forefront of the tuning market for more than 21 years and stands behind all our products with a rock solid warranty. In fact, RENNtech continues to be the tuning choice of Mercedes Benz Dealerships who not only install and service our products, but work with RENNtech directly should the need for warranty arise.
I can drive my c63 to flagship Mercedes in Boston and get a carbon airbox,filters and tuning
"While the law is designed to protect consumers it is not a guarantee that a manufacture cannot deny your warranty. A manufacturer can still deny a claim if they deem that the aftermarket component installed caused the problem. This is why selecting a reputable company with quality parts that you can trust to install and service your vehicle should also play an important factor in your tuning decision.
RENNtech has been at the forefront of the tuning market for more than 21 years and stands behind all our products with a rock solid warranty. In fact, RENNtech continues to be the tuning choice of Mercedes Benz Dealerships who not only install and service our products, but work with RENNtech directly should the need for warranty arise."
This may vary dealer to dealer - maybe your Boston dealer will install and service the product, but under the Magnuson-Moss act, the dealer will sync with their warranty claims department and the manufacturer and if the manufacturer determines the tune led to any malfunctions, at the very least you're in for a fun lawsuit. I'm due for service soon and will ask my local dealer whether they have some sort of relationship with RENNtech.
Kapish?
