Thunk when going into S, S+ or manual
/Thread
I agree that when operating normally, this car will start in 2nd when in C.
What people seem to be missing from what Alex is saying is that his car is quite possibly NOT operating normally and so starts in first.
He concedes this is not normal.
I have never met Alex in person, but I have had enough correspondence with him to know
that I would not bet against the possibility that he is, in fact, somehow maybe possibly.....you know, correct, when it comes to his own car.
Just sayin, weirder stuff has happened.
Being data driven I did some testing using the AMG screen that one person insisted would debunk what I could feel in my *** and see in the tach.
The car is going in next week once they let me know they have a TCU and a selector switch.
This week she who shall be listened to was given a pencil and a piece of paper while we were out and about with lots of stop and go driving as well as a few stops along the way. She was told to mark down what gear the car started in from STOP with it in C and brake on.
ON ENGINE START UP the car always started in 2nd gear when in the comfort selection which is the default.
In 50 stop/start cycles the car started in 2nd gear only 17 times or 34% of the time. The rest of the time it started in 1st.
Totally random.
Clearly something is not right as I suspected and being intermittent probably not something that is readily noticeable until you look for it. This may explain why on occassions I can break the rear tires loose even with the ESP on in C, I know you can do it most of the time but sometimes it seems easier which would be explained by a 1st gear start.
I fully expect they will sort it out. I want it fixed before the thing comes out of warranty in March which is February 14 as far as I am concerned because I will be out of the country from then and it will be well past its expiry when I get back.
Totally random.
Totally random.
That is why I drive 2hr to take the car in, 2 hr back home and repeat the cycle when the car is ready. I could go to an affiliated outfit 30 minutes away but as a dealer they suck. I have no doubt this will be A-Ok this time next week.
More people need to know about this easy reset.
I am not sure who told me but I understand that this procedure is the only one used by most techs these days to do the reset absent any coding issues.
No issues with idled, power etc. The thing still runs like the freakin' wind!
The only ***** I have with this car is it is perhaps even a bit more thirsty than what I expected. My 2011 E350 wagon in my mixed driving would give me 10.3 L/100 km. The CLA45 AMG that this replaced about 9.6L/100 so getting 12-13 is a bit of a step up at $1.35 CDN per L for premium ($3.80 USD per US Gal) but what price fun!
You should have noted that if you start the car in 1st manually it does not shift on its own. That is what I find whether I do down shift all the way or only part way. Whether that is normal I don't know.
My 2014 SLK 350 and 2015 CLA45 AMG would shift normally from a lower gear I had down shifted to but this one doesn't.
We will see.
Thanks for the thought but there is more here than that.
We will see.
The paddle function in C, S or S+ is different. In these gears, the car shifts automatically and the paddles are used to determine the HIGHEST gear the car will utilize. Example - coasting at 60 in 7th gear, if you pull back the left paddle 3 times, the car will shift down to 4th. If you bring the car to a stop the car will auto-shift down thru 3, 2 and 1. If you then continue driving, the car will auto shift up from 1 to 2, 3 and into 4 - but no further unless you start tugging on the right paddle to increase the max gear.
In the latter two cars in C (Eco in the CLA45) or S if you paddled down they would go down but would go back up to 7th if you did not intervene. The CLA45 had a bit of delay and flashed at you to shift but if you didn't it would shift it for you.
It was that feature than made me realize this one, when I paddled down was not shifting back up in C, S or S+ and I would force the shift with the right paddle. It did not occur to me that it might be shifting to the last gear I selected and then holding. With its issues anything I suggest anything is possible at the moment.
I will test this idea out tomorrow. Hopefully all will be resolved by the end of the week. Thanks for the input.
In C mode the car will start second unless I am on a hill, then it drops down to first almost immediately when I get on the gas. In S, S+ and M the car always starts in 1st from a complete stop...
Ed
You will no doubt read the results of my testing two weeks ago which showed this car, when in C, was randomly starting in 1st gear 66% of the time with no intervention by me.
It went into my tech guys late Wednesday this week and I picked it up today.
My tech drove it home after work on Wednesday and back Thursday and confirmed what my data told me.
He ran the usual computer checks and while there were a few anomolies nothing struck him as being the cause.
Being a well experienced tech he relied on his experience. While not a common occurrence he has seen this issue on the odd one of these cars and also on a number of the lower class versions of MB cars with the abiltity to change shift patterns by using C (or E in some cars) S or M.
Based on that experience he changed out the selector switch in the console. He drove it home again Thursday and back today and it did not happen. The car started every time in 2nd.
I drove it home and every stop resulted in a 2nd gear start.
As a test I forced a 1st gear start on half a dozen occassions on the way home and as expected I had to shift it manually from there to 7th. Every time after each test cycle it returned to a 2nd gear start when I did not intervene.
So all is back as it should be and the problem resolved.
The lesson learned is there are always new things to be learned about these cars and any MB when they deviate on their own from what experts expect.
