C63 AMG (W204) 2008 - 2015
Who here is running 275s in the rears on stock 18 wheels?
Old 03-11-2016, 11:32 PM
ELITE_KOV's Avatar
06 E55 / 13 C63
Originally Posted by QWKSNKE
Yeah I was editing while you were posting
Nice, I was looking at the MPSS in 275 as well.
It looks like they sit perfectly flush with your stock wheel? Right?
I think I'm going to get the 275 MPSS too
Old 03-12-2016, 09:55 AM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
Correct. The size is perfect for a 9" wheel
Old 03-12-2016, 12:02 PM
need2speed's Avatar
2016 S212 E400 RENNTech 345 whp/360 wtq
There must be a good reason why AMG doesn't mount these sizes? Michelin specs the minimum rim width for 245 is 8" and 275 is 9", but would you be comfortable at the edge? Tire Rack has an interesting technical article on rim widths for track use and advocates using the widest rim recommended by the tire mfg, provided they fit the car and are within event rules. I'm looking for 8.5/9.5 wheels to mount the same sizes as a compromise on my Edition 507.
Old 03-12-2016, 12:33 PM
jclaus98's Avatar
2012 ML63 AMG, 2015 RAM 2500, 1968 Charger
No, my fronts have not needed replacing yet.
Is anyone here running 255's on the front that can vouch for the fitment and maybe even a pic?
Old 03-12-2016, 03:17 PM
ArmoE55's Avatar
2006 E55
I decided to go with MPSS 235f and 265r. I figure these cars go through tires so quickly, if I'm not satisfied with the 265r, then I can try the 275r.
I have a feeling the MPSS 265 would be more than enough and make it look plenty meaty in the rear.
Thanks for the posts,
Old 03-12-2016, 03:56 PM
QWKSNKE's Avatar
Isn't the 265 more expensive than the 275?
Old 03-12-2016, 04:17 PM
  #32
ArmoE55's Avatar
2006 E55
$214 for the 265 and $229 for the 275 - I went through discounttire. Tirerack was a little more expensive.
Old 03-12-2016, 06:17 PM
  #33
ELITE_KOV's Avatar
06 E55 / 13 C63
I went with the Conti DWS - 235/265. I read great reviews on tread life and dry grip and noise level - which are my top factors.
Can anyone comment on the DWS dry grip in straight line acceleration?
Old 03-13-2016, 09:19 AM
  #34
BRV518's Avatar
2009 C63 AMG
Running 255's in the front and 285's in the rear. No fitment problems. Just makes the car look like its supposed to imo. Toyo Proxys T1's. Drag Radials in the Spring
Old 03-13-2016, 01:35 PM
  #35
need2speed's Avatar
Cool! What size rims and offsets?
Old 03-13-2016, 02:50 PM
  #36
jclaus98's Avatar
Outstanding! Any chance you can post a few pics of how it looks? And those are on stock wheels???
Old 03-13-2016, 08:17 PM
  #37
mikekuriger's Avatar
2010 C63
Here's what 265's look like. They are the same width as the rim. These are Bridgestone RE-11 and I have to say they are the most disappointing tires I've ever used. They would be great for anyone looking to easily drift their car... I'm going back to my trusty Hankook tires in 255.
Old 03-13-2016, 09:16 PM
  #38
Fudge Monkey's Avatar
Benz
Car needs tires and I'm debating to stick with the 255 factory rears or go a bit wider with the 275s. I personally like a car with a little more meat in the rears (although 255 to 275 isn't drastic, it's still a change).
I am curious who is running 275 on the rears on stock 18x9 wheels. Any issues? Sidewall problems? Rubbing etc.?
I plan to keep the 235s up front. So, 235/40/18, 275/35/18.
Currently, on the fence among four tires: MPSS, DWS Contis, Nitto Invos, or Goodyear F1s
Thanks in advance,
I'm driving 275's on the rear.
The car looks better.
But the car hunts on the road. It no longer tracks like its on rails.
On the highway it feels floaty.
Fuel consumption went up.
I felt no different in traction.
Would i do it again - no.
I'm returning to factory sizing shortly and something in ET street for traction that i couldn't get from a wider size.
Old 03-13-2016, 10:22 PM
  #39
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I am very happy with the RE-11s on my Subaru STi. They were great on the track and at autocross. Very predictable and had tons of grip. Obviously the STi is an AWD car (and there were a ton of supporting suspension mods), but at the limit the car was STABLE.
What Hankooks are you referring to?
Old 03-13-2016, 10:30 PM
  #40
QuartzBlueP31's Avatar
2010 C63 P31
I would like to see that set up also, if you have any pics!
Old 03-14-2016, 11:54 PM
  #41
QWKSNKE's Avatar
You must have a picked a poor tire or running incorrect air pressure. My 275's have none of these symptoms.
Old 04-12-2016, 11:43 AM
  #42
sharkey_lsu's Avatar
2013 C63 AMG
Originally Posted by c63Jimbo
I just got my MPSS 245F 265R installed yesterday and couldn't be happier. I first wanted 275s as well but kept reading they look too beefy on the 18s.
I can say without a doubt I love the look and stance of my car now with the 245s and 265s on P30 suspension.
Originally Posted by zcct04
The MPSS remains the best choice for a summer street tire.
I run the same sizes (245/265), and I think it's a perfect fit.
255/275 can fit, but both would need a wider wheel vs stock.
Both comments assume that you are at stock ride height.
235/275 would not only give you a too-wide-for-the-wheel rear tire (with sidewall flex issues that are not good for driveability and handling), but it would also increase the grip in the rear without a similar increase in the front. Our cars understeer already, and this would just make the problem worse.
What are your thoughts on 245/275 MPSS? I am thinking this combo would balance tire size proportions for front and back.
The circumference of both front and back would be within .4" of each other (as opposed to 1.18" difference stock). Also, the sidewall height would be around a .07" difference (down from the stock .19" difference).
So overall the front and back tires would be visually about the same...just not sure how this would affect performance/other things.
Old 04-12-2016, 03:50 PM
  #43
vipertoad's Avatar
97 Viper, 14 SRT Jeep
LOVE my Conti ExtremeContact DW in 265/35. Had 255/35 DWS on there before and the 265 DW was a HUGE improvement in traction, both in straight line and curves.
Old 04-12-2016, 04:47 PM
  #44
Sidv22's Avatar
Audi A5 6MT, C63 AMG
No sign of floatiness after installing 265?
Old 04-12-2016, 07:06 PM
  #45
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
Thanks in advance,
275 is no problem, but I was running 12mm spacers all around and 275 would rub on a p30 lowered. I changed it to 265 after.
Old 04-13-2016, 12:06 AM
  #46
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
I had 275s MPSS on the rears with the full drop on h&r coilovers no rubbing. But 275s on the 19x10s rub like crazy on every bump and can't carry any passengers in the rear.
Quick Reply: Who here is running 275s in the rears on stock 18 wheels?
