C63 AMG (W204) 2008 - 2015
front brakes
Old Mar 17, 2016 | 08:58 PM
EUROwnd's Avatar
2009 c63 amg
front brakes
hey guys I am getting ready to change my front brake pads this Sunday and the job is overall very cut and dry(unbolt sensor, remove 2 sliding pins and pull and replace)my question is when compressing the pistons in the caliper back together what is the easiest and safest way to do this without removing the caliper. Also whats the safest way to remove the old pad sensor from the pad?
Old Mar 17, 2016 | 09:06 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Use your hands
Should just slide out by hand, otherwise gently with a screwdriver
Old Mar 17, 2016 | 09:42 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
agree on using hands to push in pistons. However, my experience with prying the wear sensor out of the old pads is not good - 2 out of 3 times they crumble and break. They are only 10-15$ though, not a big deal.
Old Mar 17, 2016 | 10:05 PM
Merc63's Avatar
C63 AMG
Never been able to push Pistons in by hand, I always use a C clamp again the old pad or a screw type compressor for pushing in Pistons.
Slowly and easily pry the sensor with a screw driver.
Old Mar 18, 2016 | 02:02 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Never any need to remove the caliper if just changing pads. Use your pads to compress the pistons so that you can easily move all at once. I wedge the blade of a flathead screwdriver between the rotor and the backing plate on the pad and then just twist it, forcing the two apart.
Old Mar 18, 2016 | 04:56 AM
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Exactly what I did on my recent pad change. I changed rotors as well and there was no piston movement whilst the calipers were hanging "free". Very easy procedure.
Old Nov 30, 2017 | 05:15 PM
zzegar's Avatar
S63 AMG 2012
I just got a S63 AMG 2012 3weeks ago, Mercedes dealer informed me that rear brakes at 60 %, front brakes at 50 %, we made the deal, couple of days ago I dropped the car off for some noise check, and they informed me that the rear brakes 40 % and the front at 80%, I contacted them cause they should've replaced the rear ones before even selling it, the car been on the road 6 times only since I bought, cause I'm using another car.
Does anyone knows whats the minimum brake requirement to change, and whether should the dealership be responsible for that
Old Nov 30, 2017 | 05:19 PM
BLKROKT's Avatar
Yes, but only when it’s dark outside
Old Nov 30, 2017 | 07:54 PM
Ambystom01's Avatar
2013 C63 AMG
You're really gonna go to war over 10%? ****, talk about petty.
Old Nov 30, 2017 | 11:22 PM
AMG6.3's Avatar
C63
Lol, your new fancy car has brake sensors. When I bought my car it had 8,000 miles and the stealership said my front pads should be replaced. It got to 40,000 miles on those pads.
Old May 8, 2018 | 06:56 PM
BlackJacks's Avatar
E220 AMG W212
On the subject of Discs (Rotor) I was told, at a recent service, that my discs were under the minimum thickness. They looked fine to me so I asked why. The disc on my E220 is 32mm thick when new (that's an inch and a quarter!). Mercedes class the disc as worn out when it gets down to 30mm! I questioned how 1mm off each side made them unsafe and was then told my pads looked like they had been changed recently so I could leave until the next service. I changed them my self with new Pads and Rotors on the front and took the time to paint the calipers while they were off.
Old May 8, 2018 | 07:58 PM
Brasilianer87's Avatar
They try it everywhere, right? Same happened to me. Once in a while a poor soul falls for that, I believe.
Old May 9, 2018 | 09:26 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
These dealerships always try to extort money out of you, about raising your fears about the car needing pads or a full brake job.
