C63 AMG (W204) 2008 - 2015
M156 UPD Intake Spacer Review
Old Sep 27, 2016 | 11:58 PM
  #276
skratch77's Avatar
2005 E55
I found a pic of the dyno weather readings for the correction factors lol oh wait they were never posted on the dyno sheet lol but if u want you can blow dry your hair
Old Sep 28, 2016 | 09:09 AM
  #277
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's likely because the the height of the blower raised the inlet pipe location requiring a box redesign.
EDIT: Confirmed.
Old Sep 28, 2016 | 09:19 AM
  #278
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Old Sep 28, 2016 | 10:04 AM
  #279
s.e.a.n.'s Avatar
2009 C63
There is absolutely no real testing done on this magic intake box.
Old Sep 28, 2016 | 12:32 PM
  #280
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
Originally Posted by BLKROKT
I'm still not going to eat my sneaker
For some reason, that proposition still gives me a chuckle. I'm guessing with a wager that high, you're a pretty good handicap. lol
Old Sep 28, 2016 | 12:44 PM
  #281
Brunty88's Avatar
C63 AMG PPP Saloon
So does it works or not?
Old Sep 28, 2016 | 01:48 PM
  #282
skratch77's Avatar
2005 E55
let's see it took the engineers at amg to make more power on the sls by removing the 2 throttle body's in the manifold and putting them away near the intake filters and changing the whole intake with bug velocity stacks and a fixed runner system and tuned cams for it to make the 570hp and for the 622hp black series they upped the compression ratio on top of all this and after all that research and development they actually lost low end and mid range torque and made up for it be changing the final drive gear ratio and upping the rev limiter.
they should of just installed a spacer kit and somehow made more power everywhere without losing torque like the sls and black series did lol
Old Sep 28, 2016 | 02:06 PM
  #283
deadlyvt's Avatar
2010 C63 AMG
amg engineers use silly engineering though... These magicians use the real magic bro
Old Sep 28, 2016 | 02:36 PM
  #284
BLKROKT's Avatar
I told my friend about this thread, and he put a lot of spacers on so his wheels would turn faster. Says it's good for 50hp per wheel.
Old Sep 28, 2016 | 03:23 PM
  #285
Brunty88's Avatar
C63 AMG PPP Saloon
I was hoping for another wild debate but I got a good answer :-(
Old Sep 28, 2016 | 08:48 PM
  #286
LSAMG's Avatar
2013 C63 AMG Sedan
Old Jan 24, 2017 | 10:07 AM
  #287
Luis C's Avatar
C63 amg
Originally Posted by Celicasaur
Sadly no dyno, so you'll have to just take my word for everything here.
I wasn't able to get the spacer to fit on the rainy Friday evening that I tried to fit it on, so I simply replaced my stock filters for the Green filters that came in the package. They appeared to be the same height as the stock filters so it would make for a fair comparison of what the spacer actually does.
The car unsurprisingly was more responsive and a little better at full throttle - I suspect this was also due to the fact that I was replacing filters which were dirty and of course not at their optimum to begin with.
The next day, I fitted the spacers. Fitment was very tight, having to stretch the oem oval things upwards a little bit, but I got there in the end, after some tech support from Brooke/Exotic-Metal.
What I will say is that the oem filter on this motor is very shallow, compared to the M113 filter which UPD have a picture of on their website....so tbh even before I fitted the spacer, i was a little sceptical about the gains, if any.
The anodised red thing doesn't look too bad tbh, i kinda like it. Crucially, yes you can retain the front engine cover, albeit it's at a slight angle and not all of the dowel pin things ca reach their housings, but you'll be able to somewhat secure it on.
Normally the filter sticks out by like...15mm here....but you can't see it now:
With the cover fitted - the right side isn't on securely in this pic because i need to buy a replacement metal clip:
First impressions....ahem, call it placebo if you must, but it did feel better vs a few days ago, the car does seem to pull altogether a bit more aggressively. Whether it's just the addition of a clean high flow filter vs a blocked oem one, or the combination of the filter and spacer, but it does pull better and feel more sharper to drive. A bit more of the 'surge' towards the top of third gear is back, which I welcome with open arms.
The only way to prove it is with a dyno. My butt-dyno tells me that gains have been made. How much, I have no idea. Was it worth it...overall yes. It's possible that my car might have responded like this with a set of oem filters too, but I didn't think the kit was overly expensive anyway so I'd say it's worth a stab for the rest of you. I'm sure there will be sceptics and tbh I don't blame you. This however is my experience
Hey I am also having trouble fitting the spacer who helped you lift up the tubes.
Old Jan 24, 2017 | 10:51 AM
  #288
CarHopper's Avatar
E63S | X5
NNNNNNNOOOOOOOOOOOOOoooooooooooooooooooooo
Old Jan 24, 2017 | 11:37 AM
  #289
BLKROKT's Avatar
I LOVE THIS THREAD NEEDZ MOAR SPACERZ
Old Jan 25, 2017 | 04:45 AM
  #290
Celicasaur's Avatar
W212 - E63 AMG
That's exactly what i thought when I saw that the thread had been bumped up to the top again
This thread will haunt me to my dying day on mbworld...and all I did was give an honest review...
Old Mar 25, 2019 | 07:51 AM
  #291
RNS-11Z's Avatar
09 C63
Originally Posted by Mazspeed
A clogged filter can inhibit airflow.
A spacer to create more air doesn't equate. What obstruction are you speaking of?
You do understand that Weistec and others use this same setup on stage 2 and stage 3 systems with over 700hp. Why don't they use a spacer?
Why didn't Mercedes figure this out?
Why don't AMG's race teams use a spacer.
Simple answer here Einstein. BECAUSE IT DON'T WORK YO!
as I’m looking to improve air flow for my stage 3 Weistec set up, the stock air boxes are a massive restriction.
ive upgraded to the carbonio air box which made a good improvement. I’m looking at getting these spacers so i’l post how it goes.
Old Mar 25, 2019 | 09:42 AM
  #292
BLKROKT's Avatar
Old Mar 25, 2019 | 05:53 PM
  #293
petersc63's Avatar
c63
Don’t understand how this would help.....
Old Mar 28, 2019 | 01:50 AM
  #294
MBNRG's Avatar
To put the efficacy of Airbox Intake Spacers to the test, (or even US Airboxes vs ROW Airboxes, OEM Air filters vs AFE/Aftermarket), could we simply do an A/B Test via the MAFs, checking and recording the Airflow across each MAF corresponding to Stock Airbox vs the Spacer Airbox? (If testing for Spacers only, ensure both Airboxes are fitted with new filters, etc)
Seems this method may be able to control for more variables than Dyno testing, etc. . . altho the assumption would be equal airflow reaching intake ports on both sides (a reasonable assumption +/-)
Old Apr 11, 2019 | 04:24 AM
  #295
RNS-11Z's Avatar
09 C63
Can’t believe I almost paid $450us for that lol.
Anyways for $100aud I bought the Magnuson air boxes which replace the bottom part of the airbox. It’s significantly larger and has made a huge difference in my supercharged C63.
just letting you all know there is a better solution and for a lot cheaper
Old Apr 11, 2019 | 05:24 AM
  #296
MBNRG's Avatar
Having discussed with Ken at Magnuson the possibility and fitment of his larger lower airbox for OEM (Non-SC) application, 2 unfortunate conclusions were made:
- The larger Magnuson lower airbox does not have an attachment point to the OEM intake manifold
- This lower airbox is taller, and as such, the OEM Y-Pipe will not be able to clear it
Ken did kindly offer to fab up a similar larger lower airbox for OEM application if there's enough interest. . .
Per his specs, the filter is elevated in the box by 25mm. The airboxes are 25mm taller than stock.
Old Apr 11, 2019 | 08:27 AM
  #297
skratch77's Avatar
2005 E55
I'll take one!
Old Apr 11, 2019 | 10:57 AM
  #298
Crya's Avatar
2009 C63 P30
But if you're going to get any traction on this, you may want to start a new thread if you want to drum up interest, as this thread seems to bring out lots of strong feelings about spacers.
Old Apr 12, 2019 | 01:50 AM
  #299
MBNRG's Avatar
Unfortunately, I'm not 100% convinced either way.
Both the Spacers and the Magnuson lower airboxes increase total airbox volume over stock - by increasing lower airbox height. Magnuson increases height by 2.5cm, the UPD or VRP or skratch77 Spacers increase it by ___ cm?
(As an aside: Renntech airbox lid also has taller height vs stock lid, thereby also increasing total airbox volume, but post-air filter.)
Will this increase in lower airbox volume have a measurable increase in airflow & performance for a stock, Non-Supercharger application with stock TBs? How about with larger 82mm TBs?
We need more data.
I'm not an airflow expert, but I can appreciate that my AFE Pro Dry S air filter has an impermeable rubber surround around entire perimeter (unlike the OEM air filter, where half of the filter element height is bare), and that this rubber surround may indeed obstruct some airflow, as it reduces the cross-sectional flow area of lower airbox's inlet. Could this perceived obstruction also cause unfavorable turbulence of airflow? Quite Possibly. But what effects, if any, do these have on airflow performance in a stock application?
We need more data.
The height of both types of air filters below is slightly exaggerated (i think they're for the W205?), but illustrates the point above:
Even the OEM air filter on the left, with it's taller bare filter element exposed, is a semi-permeable membrane. Does this have any affect on airflow across this filter; does this cause unfavorable turbulence in its stock placement in stock lower airbox? What effects, if any, do these have on airflow performance in a stock application?
We just need more data.
If anyone has _______ brand of Spacers, perhaps we can put the Spacers debate to rest by collecting data with the A/B testing via MAFs in my previous post.
Dyno tuning is more costly and seems to have more uncontrollable variables.
Old Apr 12, 2019 | 05:04 AM
  #300
skratch77's Avatar
2005 E55
I think.anything that will give us more volume will help. If you look at how big the sls air boxes are compared to ours. They are huge with bigger air filters.
I think if someone makes a totally new air box with a wider and bigger bottom half along with a new bigger air filter will make power.
I'm basically maxed out on the intake side of things and a bigger airbox is my next mod I want to do.
