Brake cooling ducts and modified front bumper
If they are the Mode Carbon vents, do they come with housing/mounting brackets? Or are they just designed to replace the OEM for carbon fiber?
I'm wondering if I have to order anything from MB to get them to fit? (Part Numbers?)
did you use this rough sketch for measurements?
Got some more adjustability from the UPD rear suspension arms, so was able to lower the car another 1/2” as well. Car is real tight with all the new suspension components and the sways have made a huge difference in steering transitions. Can’t wait to get it on track.
Had some brake cooling ducts from a 996 GT3 RS fit to my front thrust arms. Need to look at redoing these when I put my Syncro Design Works monoball arms in June. Would like them to hang under the car further to scoop up more air.
Memorial Day project. Front dive planes. Going 1” wider in front and my tire is already sticking out now. Need to find someone in the NYC area who can cut 3/32” aluminum sheet to the shape of this template. If anyone has a lead I’m all ears. I’d do it myself but there’s too high a risk of the sides coming out shaped differently and that would irritate the hell out of me.
Safe Trip Back man
