Mysterious Coolant Leak
W204 C63 R171
I was wondering if anyone has had an issue with the coolant disappearing, that is not related to headbolts.
I have spent a lot of time trying to figure out whats going on and I am coming up blank.
I have uv dyed the coolant its not showing up in the exhaust or oil on the ground or any place I can see from under the car with the protective panels off.
I have replaced the coolant tank cap as it was advised that sometimes these go bad.
I have replaced the coolant hose with the plastic t because they also go bad mine was steps away from blowing apart, I though this is where the leak was.
This morning I pressure tested the system and it wont hold 10psi for any substantial length of time and as small amount of coolant maybe 1/16" - 1/8" has come out of the tank.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
If it's not going out the exhaust----it's gottabe dripping out somewhere and falling to earth-----have you put paper under the car or taken the time to put the car on a lift and let it run and run to locate the leak!!
Received 2,841 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
No observable leak. Not holding pressure. Not in oil. I'd bet on a slight head gasket leak, and the coolant is getting vaporized in the cylinders before getting anywhere else. I don't think that would show in oil. But if your system is not holding pressure, it has to be going somewhere and disappearing.
W204 C63 R171
Yep its what I feared, Mercedes Benz wont even chip in a nickle and they know it's a poorly engineered part, I am so upset about it I am going to sell the car and never buy another Mercedes product again. Anyone with one of these ticking time bombs should sell their's too so your not left holding a live grenade. My car only had 57,000km on it. Yes its a 2008 but some attempt could have been made to help out. Thing that ticks me off the most is back in 2012 I had to add some coolant, I figured it was just because its a 4 year old car and used some up so I just added it I should have probably had it pressure tested then maybe they would have found something and it would have been covered under warrenty at 35,000km.
I was a big time Mercedes AMG enthusiast now I have never owned any other brand of car, but this whole situation has ruined that for me.
2010 Irridium Silver MB C63 AMG Sedan
Let me get this straight...
You own a matured miled 2008 C63, have coolant leak, might have to pull the heads and change out the headbolts etc., and your upset that, now that your out of warranty, your butt hurt that Mercedes Benz won't come to your house, wipe your rear end for you and pick up the tab 100% for your engine coolant leak, and now your so angry that you won't ever buy a Benz product again?
You need to grow the HELL UP and stop whining like a 6 year old. It's a high performance machine, of moving parts, man made, and things happen. No man made machine is EVER guaranteed for life. There is no UNCONDITIONAL lifetime warranty on anything in life, unless maybe if you own a jar of pickles from Costco.
As much as it sucks that you are going through this, but your mental position and your thought process on accountability is way off. Your pattern of thinking makes you the type that probably would hold the government responsible for making sure it provides you breakfast on the way to work.
I had no headbolt problem but spent the money out of my own pocket to get them replaced and the engine properly serviced.
If you want reliable, go buy a Yaris. Not saying the C63 is an F1 car but with higher performance needs higher maintenance, preventative maintenance, constant maintenance, and perhaps higher failures over time and use.
Your whining cry baby, "it's all their fault all the time" attitude should exclude you from ever owning a Benz AMG or any higher performance car ever for that matter.
Stick to Kias and Toyotas.
The following 2 users liked this post by ZephyrAMG:
BLKROKT (06-11-2016),
hammadyousef (09-08-2022)
It's an 8yr old car dude. Doing the headbolts and gaskets isn't the end of the world man. Car will be as good as ever after the repair. Be thankful you didn't lock up the engine and get on with it.
I agree MB should stand by their brand. If I had to redesign a part because of a discovered defect, I would at least heavily discount the new part if not give it away to replace defective one.
W204 C63 R171
The ratio of the cost of the repair to the cost of the car is much to high, I can understand the cost on a $200,000 car but one that cost $70,000 and having to put a rebuilt engine for half the price of the car, call me butthurt all you want. It's a known problem. I wouldn't consider a 2008 with 57,000 km NOT MILES to need an engine rebuild, I have 2 1969 455 7.4L big block engines here with the orginal headbolts and 5 times the mileage and age.
I could understand them not wanting to help if it had 100,000km on it or 150 or 200k but 57,000 KM its a new engine still.
You can call me what ever you want but once the coolant is in the oil the engine basically needs to be totally rebuilt as you now have coolant in the crankshaft bearings as well and any place the oil lubricates.
I didn't ask Mercedes to cover it, they could at the bare minimum cover the 200 dollars for the bolts THEY designed and specified that THEY installed, They broke when I drove the car under normal street use only 3400 km a year. I have three different 2008 mercedes benz products they all have faults nothing is made to last more then a few years.
ZephyrAMG please do tell me who should be accountable for this problem I am having. I guess with you logic I own it so its my problem
My logic is its cheaper to spend 5 to 10K on 60000 engines with fault bolts then loose out on 60000 $100,000 sales on new C63's
Do you work for a dealership?
optimusprime m1 (06-14-2016)
[B]The ratio of the cost of the repair to the cost of the car is much to high, I can understand the cost on a $200,000 car but one that cost $70,000 and having to put a rebuilt engine for half the price of the car, call me butthurt all you want.
You knew this (or should of knew this) getting into a high performance German import.
Help? Wanting them to "HELP"? The manufacturer gives you a 4 year, 50K mile warranty. Its fitting. No manufacturer can chase and follow you around the earth making sure your purchase of a high performance machine is in good hands and well taken care of. They can't babysit everyone. They give you a great time frame to use the car and come back to them with any issue you may have and they will repair it 100%. Outside of that it would be ridiculous to follow you and make sure you are consistently satisfied.
Who can prove that you used it "normally"? What is "normal" anyway? Cars are man made and they are engineered. Parts fail. It's the nature of the concept.
ZephyrAMG please do tell me who should be accountable for this problem I am having. I guess with you logic i own it so its my problem
Bottom line, the car has been owned well outside the 4 years, 50K miles and it would be unfair to hold any manufacturer 100% accountable for everything forever. It just doesn't make sense. Benz in no way maliciously designed poor headbolts. They honored an unconditional warranty for 4 years/50K miles, but beyond that at some point they have to say now it is upon the owner to be responsible. Some people thrash on their cars all day long and some people granny their cars. Where does one draw the line?
My logic is its cheaper to spend 5 to 10K on 60000 engines with fault bolts then loose out 60000 on $100,000 sales on new C63's
I am not understanding what you are saying here.
W204 C63 R171
Since your hooked on miles my car only has 35418 miles, the car was bought from mercedes as a lease return so it was maintained correctly all its life and not abused.
LOL relax. The guy is just expressing his frustration. It's not normal for a HB to stretch/break.
Heavily discount the parts? I can understand a slight discount but that's like saying heavily discount the parts needed to repair my 15year old projector TV because the bulb blew. With relation to todays TVs, those TVs suck. But it was great for the time. Just doesn't make sense.
That is a fairly low miles/kilometer 2008 C63.
My point is that the manufacture gives a decently generous unconditional warranty for 4 years/ 50K miles and beyond that it's just impossible to cover everyone forever...just doesn't seem reasonable.
Most of us who get into these German cars know that there will be expenses and failures and by KNOWING AND BEING FINANCIALLY AND MENTALLY prepared to deal with issues should they arise.
We buy these cars because they excite us, not because we are worried of repair bills.
W204 C63 R171
5 thousand dollars x 60000 engines that have the bad bolts = 300 million dollars expense.
100 thousand dollars x 60000 pissed off customers who don't come back and buy there car = 6 billion dollars in lost sales
Wouldn't it be cheaper to pay 300 million to make 6 billion in sales.
You can kiss someones *** and make them feel important without spending a lot of money doing it. Without people buying there products they have no business, only problem here is for every 1 of me there are 5 people waiting in line to buy there Mercedes status symbol to impress there friends.
The man made argument is nonsense the head bolts are torqued all simultaneously with a computer control torque machine, there is no frieder in the factory with a torque wrench like I have in my garage. The only flaw here is the engineer who speced the bolts they realized they made a mistake so they corrected it, but they should do something anything even just 200 dollars to cover the bolts for anyone who would have
I get this passionate about it because its more then just an A to B car for me I spent hours working on it changing the oil, cleaning it spotless, tracking down parts I wanted to install etc and doing everything I can financially afford to keep it tip top. Its time for a change for me anyways.
W204 C63 R171
I am relaxed. It's Saturday and I read the forum with my coffee in hand. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
It's not really a repair or a part that simply wore out that's infuriating its replacing a known defective part that Mercedes/Amg designed incorrectly
One as integral as a head bolt is pretty pathetic that they don't replace them it I hate to break it to you other brands hide/bandaid similar screw ups it's just part of the game
While I won't be as abrasive, you need to evaluate what you're buying more thoroughly next time. I recommend to you that you always own a vehicle under warranty and let it go near warranty end.
I understand your frustration that they wont help at all, but they aren't bound to. You can go buy any high performance car and end up in the same situation. Heck, you can buy ANY car and end up in this situation. It'll just be easier to fix a 2 liter toyota than a 6+ liter AMG. You know this...
To come back and say you'll never own Mercedes again, well, we'll see you back when you run into these types of problems with all other brands. They ALL have issues one way or another. If there was a flawless car brand out there we would all own that car / brand.
If I were you, I'd fix your car. As you say yourself, it is low mileage and overall in great shape aside from this one thing. Once you fix it, it goes back to being that low mileage, high performance car, that until this point you've probably really enjoyed. It is out of warranty, so just go to a third party and don't pay dealer prices.
It happens, I'm sorry it happened, but things like this do and will continue to happen across all makes and models. If you can't handle the price to repair than perhaps purchasing a cheaper vehicle that is more within your means is a good idea. That's not a dig at you and I'm not sitting here all high and mighty like I have more money than you and a bigger dong so don't take it that way. (Ha, I don't even have a comma in my bank account at the end of each month). It's just real advice from someone who can appreciate the situation you are in and have put some real thought into it myself.
I think I should be able to walk into my local MB dealership, dump the bag full old HBs on the counter and get a refund for the re-designed bolts I purchased out of pocket.
I feel OP frustration, it is unacceptable for such an high end company like MB to not honor the headbolts problem. This is a known defect, this should have been a recall from day one.
Zephyr, not to take side but I don't think everyone feels like spending 5k$US as preventive measure to correct something MB failed to install correctly.
Yes we have the 4 years 100k km warranty, but some of the ppl I've known kept having the coolant message light popping up but was refused by MB to replace the headbolts under warranty. They were told it needs to snap first... Really? That's a joke...
optimusprime m1 (11-23-2019)
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
not to take sides or anything but i feel OP's frustration as well. but to say that youll never own an MB again coz of this is a bit much. MBs are far more reliable than a lot of other car brands.
Zephyr, not takin a stab at you but not everybody thinks the way you do, or has 5k readily on hand to tackle this the minute it happens.
OP, next time, you might wanna do a bit more research when purchasing a car. its a known issue and since you bought the car used...should have would have could have.
Even when I purchased it I knew "AMG" meant expensive maintenance and high performance = more possible failures.
So many people buy these cars whether its M or AMG and completely freak out and jump ship if the car ever has anything wrong with it. German cars have ALWAYS had issues. I just don't understand that when something goes wrong that owners have a mass exodus on the brand. It's unfair to think that the C63 AMG must be as reliable as a Corolla, or that if something goes wrong out of the warranty phase, that the manufacturer must pick up the tab unconditionally.
Overall they do a decent job at TSBs and initial warranty work. I guess as Americans we just expect to be served and taken care of from cradle to grave...
I agree Zeph & beej about OP overacting about not wanting to buy another Benz. I'm sure he cooled down already & found a local shop to do the repairs.
On the other hand, I would still buy an 8k$ set of HRE vs spending 5k$ replacing my potential defective headbolts. After spending 80k$+ on a car, I don't think I should be spending an extra 5k$ to replace smth the manufacturer screwed up.
I'm sure most ppl think the same way .. Why fix what's not broken lol
ZephyrAMG (06-15-2016)
